Engine Noises
Old Apr 12, 2011 | 05:12 AM
dohadex's Avatar
dohadex
I have read the threads regarding this "noise" and now I don't feel mine is unique or abnormal.
This loud ticking sound has to mean there is metal to metal contact going on and that means wear, which can lead to a failure. I switched to Mobil 1 20w-50, and no difference.
Maybe the MoCo is avoiding a recall by alerting dealer techs that this is "normal" and within specs. BS!!
Old Apr 12, 2011 | 06:31 AM
Notgrownup's Avatar
Notgrownup
cut the push rods with a bolt cutter and install a set of SE Quick install adjustable pushrods. My 07 ticked like a freakin set of drums and after my cam install and the new push rods it's quiet now. By the way...it ticked for 55000 miles.
Old Apr 12, 2011 | 08:11 AM
cuda67bnl's Avatar
cuda67bnl
If any of you guys ever tear into your motors and start measuring clearances, you'll see why they tick so much. The tolerances are rediculous. There's slop room everywhere, especially in the rockers.
Old Apr 26, 2011 | 01:37 AM
Harleyboyddk's Avatar
Harleyboyddk
The noise is probably normal. My '03 made alot of racket until the hydraulic cam chain tensioner upgrade with adjustable tapered pushrods at 45,000 miles. Real quiet now.
Old Apr 26, 2011 | 02:09 AM
fireaxxe's Avatar
fireaxxe
Thats exactly where the noise is coming from i just recently shimmed my rocker boxes up and the noise is gone. The valve train geometry in these engines causes the rocker arm to wear on the support plate once you get a few thousand miles on the motor the wear levels out. Your left with large tolerances that allow the rocker arms to move side to side causing what you are hearing.
Old Apr 26, 2011 | 02:16 AM
103 sedona orange's Avatar
103 sedona orange
My 07 FLHT STD made so many noises from everywhere. I never had any problems with the engine. Now I have a 2011 FLTRX 103 & this engine is quite compared to my 07. But do have the HD shop check it out.
Old Apr 26, 2011 | 06:51 AM
FDHOG's Avatar
FDHOG
I have a 78hp sewing machine between my legs with a box full of marbles attached to it, but it has a 5 yr warranty.
( yeah extended warranties suck, but there are Indy's around here that do HD ext. warranty work )
You said you're running Mobil 1. Synthetics are just going to increase the noise you hear.
I noticed it more when I switched to Amsoil.
fireaxxe
Feb 9, 2019 02:38 PM
mhodge
Apr 16, 2018 12:39 PM
aajjay
Aug 27, 2012 11:45 PM
1931jamesw
Oct 14, 2011 11:08 PM
rdub
Exhaust System Topics
Jun 29, 2009 08:45 PM
