Got a question
Old Oct 20, 2006 | 04:50 PM
04RoadKing's Avatar
04RoadKing
Default RE: Got a question
ORIGINAL: dchoran
05 Ultra - 112 mph tops as stock.
New pipes, PCIII, Stage 1, dyno = 156 mph WOT - downhill with a breeze [:-]
Dude what are you smokin ? 156mph With an Ultra Yeah right.....................
Old Oct 20, 2006 | 05:00 PM
dchoran's Avatar
dchoran
Speedo only goes to 120.
So when it went past 120 and became vertical pointing straight down, I assumed it was about 156mph or about 30% faster - counted the lines on the gauge.
Things happen pretty fast at that speed too - suspension seems really funky - like slow mo - and it wasn't too bad with the 15" windshield (vent closed).
Old Oct 20, 2006 | 05:03 PM
AK_Hog_Herder's Avatar
AK_Hog_Herder
The drag of the sidecar will hold the unit back and it is worse with a stiff head wind. I know a few people running side hacks here and they have the same issue.
AFAIK, only a bigger motor and a good tune will improve things. But you probably don't want to be going much over 90 with a side hack so look at it as an investment in passing insurance.
Old Oct 20, 2006 | 06:52 PM
04RoadKing's Avatar
04RoadKing
ORIGINAL: dchoran
Wow 156MPH on an Ultra ????[sm=confused06.gif] What do you have for Engine mods? Are you sure you don't mean kilometers per hour? Dude I really hate to burst your bubble but it would take an awful lot of engine work for just about any Harley Davidson to do over 150MPH, let aloan a Bagger. I think the VRods top speed is only around 140MPH.
Dude you might want to get your Speedo checked out.
Old Oct 20, 2006 | 07:05 PM
two dogs's Avatar
two dogs
LOL
Old Oct 20, 2006 | 07:32 PM
SeaHag's Avatar
SeaHag
With the higher ratio of the overdrive sixth, he may have to get that motor spinning higher before he drops it into top gear. Have him rap fifth gear up to atleast 5,000 rpm before going into overdrive and then see what his sixth speed will carry. I used to think that my bikes top speed was about 105, even with all the motor work I've done...then I tried it again while rapping fourth gear up to about 5500 rpm before hitting fifth gear...I shut it down at 115 because the front end was getting scary light.
Old Oct 20, 2006 | 07:55 PM
jmorton10's Avatar
jmorton10
ORIGINAL: dchoran
In a dead freefall off a cliff maybe, an Ultra will never come anywhere near that speed any other way........
~John
Old Oct 20, 2006 | 09:24 PM
rwagon57's Avatar
rwagon57
Damn! the fishing in this pond is good[sm=happybounce.gif]
ORIGINAL: dchoran
Old Oct 20, 2006 | 09:50 PM
DoCPooF's Avatar
DoCPooF
Guys...after getting a closer look at dchoran's dash it's quite possible he got up to 156mph.
Here's a closer look!
All in good fun Dave, hope you're not offended.
Old Oct 20, 2006 | 10:11 PM
asuperheat's Avatar
asuperheat
I have a buddy that ownes a cvo electraglide classic motor built by carls speed shop 117" high comprssion very strong bike on the top end over 130hp on the dyno and it tops out in the low 140's it would take a lot more to get it over 150 that would be very hard to do and very scarry to ride.
