No power past sixty
Old Apr 15, 2011 | 07:16 AM
1flhtk4me's Avatar
1flhtk4me
Originally Posted by n8dc
Well if I was you rather than take the B/S and the backyard mechanics ideas here is just make an appointment with a dealer .
There are a lot of good "backyard" mechanics here!
At least they wont bend you over and do it dry like some dealers do with their $90+ hourly rate.
Old Apr 15, 2011 | 09:47 AM
RevBlk's Avatar
RevBlk
More than likely bad fuel. Drain it & give it to someone you don't like. Put in fresh fuel and check your air cleaner. My old carb bike did the same thing every spring for the first tank or two of new fuel even with Fuel Stabilizer in it. My 07 FI doesn't seem as badly affected though. Fuel filter is supposed to be good for 50,000 but you know the quality of fuel in your area. Then again, What do I know? I'm not a certified MoCo technician.
Old Apr 15, 2011 | 09:55 AM
longrideshields-1's Avatar
longrideshields-1
Premium Sponsor
as for the fuel issue, try putting just a little sea foam in your tank and riding through it.
The power issue to me actually sounds like a flooding issue, although strange on an injection engine. Change your oil and look at the consisancy of the fluid if it has gas in it you may have a larger problem. Most bikes loose compression and backfire when slightly flooded.
I would have the clutch investigated as well, but you can change your filters and oil at home and its a good thing to do regularly anyways.
__________________
General Inquiries:
Info@LongRideShields.com
Sales and Marketing:
Sales@LongRideShields.com
Phone:
775.331.3789
Old Apr 15, 2011 | 10:11 AM
Garcou's Avatar
Garcou
Sounds to me like you have a intake leak, those exact symptoms effected my buddy last year, bike would run fine, then once warmed up would not go past 55. We initially thought fuel filter, but ended up pulling the intake and lo and behold the evidence was plain as day. Something to consider! Of course you can take what this back yard mechanic says with a grain of salt if you wish
Old Apr 15, 2011 | 10:44 AM
mrfikser's Avatar
mrfikser
I read somewhere that the problem might be the plug for the fuel injection...something about it not making a good connection and causing the slider to not open all the way..anyway pull the plug apart and look for corrosion clean it and add some dialectic grease
Old Apr 15, 2011 | 02:41 PM
Parker925's Avatar
Parker925
I'll take the backyard mechanic route any day. Thanks for all the help. If the f-in weather ever gets cleared up out here I'll take the bike out, clear up the problem and get ridin' again.
James Gargs
Mar 21, 2019 05:22 PM
SGT Rock TN
Exhaust System Topics
Jan 23, 2014 04:11 PM
Badillac
Jul 10, 2012 03:34 AM
TheSeeker
May 18, 2010 05:13 PM
DrSmaggs
Nov 5, 2009 09:40 AM
