Tour-Pak Mounting Rack Question
Old Apr 15, 2011 | 03:56 PM
LoBoy's Avatar
LoBoy
Hello all. I am the one with the tour pac rack. My backrest mounts to the upper shock mount with the front hooks. The rear hooks of the back rest mount on the forward docking kit points. The rack is narrower and it almost fits with the front rack hooks going on the inside of the back rest and the rack’s back hooks mounting to the rear docking kit points. Like I said, ALMOST. The rear hook is not cut out enough. Either the measurement between the centers of the docking kit points is off, or the center point of the “hooks” is incorrect.
The width is not the problem; it’s the distance between the “hooks” on the rack. I have used the backrest with a luggage rack, so I know the docking kit is correct. Any other thoughts?
Attached Thumbnails Tour-Pak Mounting Rack Question-img_4291.jpg   Tour-Pak Mounting Rack Question-img_4292.jpg   Tour-Pak Mounting Rack Question-img_4293.jpg
Old Apr 15, 2011 | 04:11 PM
larsfum's Avatar
larsfum
Aren't the quick release latches supposed to mount on the inside of the rack? That's how it is on my 1998.
Old Apr 15, 2011 | 04:17 PM
viperr817's Avatar
viperr817
push a little harder it should go.
Old Apr 15, 2011 | 04:22 PM
DPete's Avatar
DPete
If you rotate the latch around will it latch?
Old Apr 15, 2011 | 04:26 PM
LoBoy's Avatar
LoBoy
No I cannot get the rack down onto the docking point in order for the latch to grab the pin. When the rack is being mounted, the rack itself hits the rear docking point, rather than going into the rack's cut-out, pocket, whatever you want to call it, allowing the latch to be closed.
Old Apr 15, 2011 | 04:34 PM
DPete's Avatar
DPete
Mine is off right now but pretty sure it sits on the latch, raise up on the rack and rotate the latch around 180 degrees from your pic and see if it won't line up.
Old Apr 15, 2011 | 04:56 PM
RollaMo's Avatar
RollaMo
Take a look at these. Even though it's for the luggage rack, the Tour-Pak bracket and mounting is the same.
Make sure you have it seated fully forward on the front mounts.
Then align your quick release latches as shown. Then while pushing straight down on the rack, rotate the latches into the locked position.
Old Apr 15, 2011 | 05:12 PM
sprintrps's Avatar
sprintrps
Thanks everyone for your help. I think we figured it out. He needs to add the "forward" docking hardware to install the rack. He was trying to use the shock tower mount as a dock point.
Old Apr 15, 2011 | 05:15 PM
DPete's Avatar
DPete
Pic worth 1000 words, I feel better now.
Old Apr 15, 2011 | 05:24 PM
RollaMo's Avatar
RollaMo
Well, the pictures he posted show the 4-Point docking hardware.
There is no forward docking hardware to add.
You either use the 2-Point or 4-Point hardware.
You are correct though, you don't use the shock tower to mount the rack.
The back rest uses that though.
For the Tour-Pak, you remove the backrest and use the 2 mounting points on the docking hardware.
From what I can tell looking at the picture, he just needs to rotate the quick latch like I showed in the pictures I posted.
merlin41
2018+ Softail Models
May 23, 2019 05:33 AM
SnoRider
Jan 19, 2016 01:19 PM
Rattletrap 96
Jun 13, 2014 09:28 AM
jfab6969
Touring Parts
Oct 1, 2012 08:26 PM
pauletich
Jun 2, 2010 09:57 AM
