SE exhaust baffles
Old Apr 16, 2011 | 05:36 PM
crazycanuck's Avatar
crazycanuck
Default SE exhaust baffles
Just wondering if anyone has ever taken the baffles apart on SE mufflers and removed the packing. I would like my bike to be a little louder without removing the stock SE mufflers on my 2006 FLHTCUSE. Thanks!
Old Apr 16, 2011 | 06:01 PM
Jallie's Avatar
Jallie
I was asking the same question for ma Softail-Custom I've just bought:
--> how to remove the baffles on SE exhaust
Old Apr 16, 2011 | 06:31 PM
axel black's Avatar
axel black
I had the 06' screaming eagles and some thought they were loud. Looking at them when off they looked by design to be restrictive. Hang on to them, might be able to sell. OR pull out the baffle and run the bike see if you like that. I went with the CFR and they put out the most deep sound I have ever heard. But beware, wannabe tuners say they cant tune with this pipe. They have NO restriction to create back pressure.
Old Apr 16, 2011 | 06:35 PM
7125's Avatar
7125
Thumbs up
check out fulsac.com he sells baffles for them i used his 2.25
Old Apr 18, 2011 | 12:25 PM
Jallie's Avatar
Jallie
I succed to put off the baffles from my SE exhaust 2in2 pipes
but not very easy if you have not the right tool to put off the two little pins first.
after , more muscles to put off main baffles ...with a max of the fiber.
but they are to noisy (not loud ) with nothing , and the engine seems not strong at all
so , I 've just put back the 1/3 of each baffles , just the first 5cm of the tube
it's just finish ... I will see tomorow morning , how much , this will improve the feeling of riding
Old Apr 18, 2011 | 01:20 PM
Pumba11's Avatar
Pumba11
I think it depends which SE mufflers you have. If you have the 65115-98B mufflers that were available in 2006 the answer is no. They have sealed baffle "cartridge". However, if you have this model you can pull the baffles and order new, louder baffles from SuperTrapp.
dale44
Jun 16, 2013 10:34 AM
Mich
Jun 4, 2012 09:17 AM
dlhike
Jun 21, 2010 11:16 AM
virtualmike13
Jan 27, 2008 04:13 PM
Wide06
Oct 2, 2007 11:44 PM
