Spot Lights,when do you use them?
Old May 30, 2011 | 05:22 PM
  #131
slhanks4's Avatar
slhanks4
I've never turned mine off. I want to be seen by the cagers.
Old May 30, 2011 | 05:44 PM
  #132
SCFLHX's Avatar
SCFLHX
I have fog lights on my highway bar that are cut on every time I take the bike out. Use every means you have so cages will see you, keep them on.
Old May 30, 2011 | 06:17 PM
  #133
2%er OG's Avatar
2%er OG
fluent them, if you got them, always on
Old May 30, 2011 | 06:57 PM
  #134
DeputyMike's Avatar
DeputyMike
On all the time!
Old May 30, 2011 | 09:25 PM
  #135
smithbrl's Avatar
smithbrl
On all the time-Hi beam/lo beam, day or night.....I think that if it were legal to run them with hi beams they wouldn't be wired to be on only with lo beam. My pick up's fog lights go out on hi beam also.....Cecil
Old May 30, 2011 | 09:32 PM
  #136
dcom's Avatar
dcom
On all the time
Old May 30, 2011 | 09:36 PM
  #137
iwillfixthem4u's Avatar
iwillfixthem4u
On all of the time. want all of the help being seen
Old May 30, 2011 | 09:37 PM
  #138
Airborne Limited's Avatar
Airborne Limited
All the time. In fact, I'm getting ready to add some caliper mounted fog lights and to re-wire the spots so they will stay on when the hi beams are on.
Old May 30, 2011 | 09:45 PM
  #139
Rat1's Avatar
Rat1
When properly adjusted, they should not throw light out any farther then what the low beam, center light does. There should not really be more glare from them then running the single low beam, just a wider light pattern.
So if you are getting the high beam flash then you need to adjust your spots downward a little.
I have not rewired mine to stay on with the high beam yet but it will be done int he near future.
Old May 30, 2011 | 10:48 PM
  #140
2008FLHRBP's Avatar
2008FLHRBP
mine are always on except when i get it back from being serviced at the stealer they always turn them off.
