Lost Throttle response
Old May 14, 2011 | 07:58 PM
Rattler77's Avatar
Rattler77
HD knows this is happening. If you are in Warranty make them fix it, if not, it is not a difficult fix if you can do your own work. Check out the page vtwinbob or look at the thread noted early in this discussion. Good luck I just went through it.
Old May 14, 2011 | 09:57 PM
TickTock's Avatar
TickTock
2101, 1511 are being fixed via a new download into the ecm from the factory. If you get these codes, ask your dealer to call the moco as the download is not available for general use yet.
Old May 15, 2011 | 06:30 AM
Duggr's Avatar
Duggr
Went to pick the bike up that Friday afternoon, shop was busy, pins were not replaced, a tec put it back together with a little grease of sort, bike has run fine since.
Old May 15, 2011 | 08:13 AM
Geezr Glidr's Avatar
Geezr Glidr
Mine did the same thing. The fix was replacing the wiring harness that goes under the fairing. If it does it again, pull over & shut down for 10 or 15 seconds. Then fire it up again, and mine ran fine ----- maybe only for another mile before I had to do it again, or maybe for a month before it does it again.
Old May 15, 2011 | 09:38 PM
Potato_Potato's Avatar
Potato_Potato
TT418: DTCs P2135 and P2101 Theory and Diagnostics
Old May 16, 2011 | 01:10 PM
audettd's Avatar
audettd
Just had my throttle sensor replaced last week by dealer.
EdsRoadGlide2017
Aug 24, 2017 08:33 AM
ezryder62881
Nov 2, 2016 08:09 PM
ije
Apr 14, 2014 07:47 AM
sstlcm08
Jan 23, 2011 12:20 PM
triked
11
Apr 14, 2010 03:33 PM
