Upgrade to 103 from 96
Old Apr 26, 2011 | 07:36 PM
hdelectra's Avatar
hdelectra
My buddy had his done a couple of years ago and laid down $2000 (SE Big Bore, 254's, etc) including dyno-tune.
Old Apr 26, 2011 | 07:42 PM
Bluehighways's Avatar
Bluehighways
Bought a set of used 96" Cylinders on eBay, a set of 103" 10:1 Hyper-eutectic Pistons from Kieth Black, Locally machined Cylinders, Cometic 0.030" Head Gaskets, Andrews 26H Cams, SE Clutch Spring, Gaskets, Oil, New Spark Plugs etc. Total cost was just shy of $700. Did the labor myself one Friday evening. Could have used different Cams (used 255's), Different non-Cometic MLS Head Gaskets, not changed the Clutch Spring, and used my exisitng Cylinders (but would have had to wait for the machinist) and I could have kept the cost under $500.
Old Apr 26, 2011 | 10:04 PM
Yukon42's Avatar
Yukon42
Got the complete stage II kit off ebay for $430. Already had pipes and SE A/C; sold those items from kit and my net cost was $230 for the BB kit. Helped a friend install his a few months ago; piece of cake. I decided to upgrade a few things while I'm in the engine (cam plate; oil pump; inner cam bearings; thinking about compensator upgrade too). As you can see by the posts here, the components/kit can be had for relatively little money, the big bucks is paying for the labor for install. You can save a bundle doing it yourself, it's not rocket science. You'll need to remap your fuel injection system which is $300 to $400 for a dyno plus cost of the tuner. Fuel moto will sell you a tuner and preload a map which will be damn close to being spot on to save the cost of a dyno if you're so inclined.
Old Apr 26, 2011 | 10:11 PM
Tek74's Avatar
Tek74
Originally Posted by shortleg
I am looking at upgradeing to a 103 with cams.
I know this is a hard one ,but what is a ballpark
price for this.
Shortleg[Dave]
I say skip the 103 and go with a 107 Fuel Moto Kit. My bike came with a 103, but if it came as a 96, I would definately go the FM-107 route.
Old Apr 26, 2011 | 10:16 PM
scotracy's Avatar
scotracy
What is the big deal bout Fuel Moto sponsoring the touring link? Does not make it the God of the vtwin world... if the man wants to do a 103.... than so be it...
Old Apr 27, 2011 | 05:49 AM
troop's Avatar
troop
I hear ya on that. Many deals can be found on H-D SE 103" flat tops from divided/separated kits. Many dealers may sell them for $140 after 20% off. Hell, I got pistons and had my cylinders bored-honed for total of $240. Even the experts will tell you the difference between a well matched, nicely tuned 103"/107" may be a matter of only couple hp/ft-lb tq and you can save couple/few hundred $$. If you're in no hurry, ebay can be a friend. For NEW items delivered I paid: SE 103" flat tops $120, Andrews 54H cams $208, Cometic .030 top end kit $60, Cometic cam service kit $35, 99B lifters $85, Torrington bearings $12, Barnett hd clutch spring $21, SEPST tuner $225, TPE manual compression releases $40. If you can do the work yourself it's a great deal.
Old Apr 27, 2011 | 06:17 AM
joslinj's Avatar
joslinj
The big deal is Fuel Moto is a great company and has given more to the forum then they have gotten back...Purchase all the parts for the 103" off EBAY or your dealer and when you come to a install or drivabillity issue give the seller a call and see how much they don't help you. Fuel Moto actually cares about thier customers and you cannot put a price on that...That makes them the "god of vtwin"
Old Apr 27, 2011 | 09:35 AM
troop's Avatar
troop
They are an extremely good company. Jamie tuned my Kawasaki and I also have some Jackpot sip-ons. Quality stuff for sure BUT their are other options. And I just can't quite hear Jamie saying in his best Charleton Heston voice "Thou shall not ride any other build but mine" being a vtwin God and all
Old Apr 27, 2011 | 09:50 AM
qtrracer's Avatar
qtrracer
I wouldn't do a 107 no matter who sold the parts. Edit, I would do the S&S 106 as the cylinders should be stronger and they can be bored 1x.
Old Apr 27, 2011 | 10:51 AM
CigarCritic's Avatar
CigarCritic
You are insinuating the walls are too thin after a 107 bore. Please provide data to back up your claim.
