Upgrade to 103 from 96
Old Apr 26, 2011 | 11:15 AM
shortleg's Avatar
shortleg
Default Upgrade to 103 from 96
I am looking at upgradeing to a 103 with cams.
I know this is a hard one ,but what is a ballpark
price for this.
Shortleg[Dave]
Old Apr 26, 2011 | 11:21 AM
RGB11's Avatar
RGB11
Have seen it advertised for $1600 including labor (does not include ECM recalibration, etc.)
Old Apr 26, 2011 | 12:38 PM
Hamps's Avatar
Hamps
I did mine new in 08 and I believe it was around $2300 including SERT and dyno.
Old Apr 26, 2011 | 01:16 PM
Red.Road.Glide's Avatar
Red.Road.Glide
Well, I'm getting my done right now...on the lift this week.
96 to 103 SE Big Bore Stage II w/SE254e's, V&H Pro Pipe H/O 2-1, SERT, Dyno...$3080.00...from Thunder Tower HD in Columbia, SC. I don't think that's out of line w/similar builds from other shops w/pipes, that I've seen. It's all being done at once, I've not upgraded any of it as of yet; so I'm not carrying pipes, A/C, or tuner over to this build.
Old Apr 26, 2011 | 01:24 PM
troop's Avatar
troop
Had mine done two months ago. My dealer charged 10 hours labor @ $75 hour = $750. Broke it down into (3) hours cams and (7) hours top end. The tune will be $225 when fully broken in. I supplied all the parts (pistons (SE flat tops), cams (54H), gaskets (all Cometics .030), bearings, clutch spring. With fully ported heads/radius'd valves/1.900 intakes/84 CC chambers/compression releases and bore-hone, I will have about $2000 into the build. Only 275 miles on it now but it is real crisp...
Old Apr 26, 2011 | 01:26 PM
CigarCritic's Avatar
CigarCritic
price for this.
Shortleg[Dave]
Our forum sponsor is Fuel Moto, take a look at their 107" kit. It's a much better deal that a dealer 103" and a lot more proven power.
http://www.fuelmotousa.com/power_packages.htm
http://www.fuelmotousa.com/107kit.htm
Old Apr 26, 2011 | 03:20 PM
qtrracer's Avatar
qtrracer
The 103 is your best bet for overall flexibility. You can find pistons and rings for it many, many ,many places, you have different types(domed,flat, forged cast,varying compressions) to choose from and can go oversize if the need arises. Unless you need that last bit of HP that 4ci gives, don't back yourself into that corner.
Old Apr 26, 2011 | 04:11 PM
capbenedict's Avatar
capbenedict
Mine cost 1680 plus tax. This included the new MAP. The cool thing was they said they didn't care what exhaust they put back on the bike. I gave them my choice. Runs great! never misses a beat.
Old Apr 26, 2011 | 07:20 PM
6 gun's Avatar
6 gun
well if you go with SE the jugs are going to be around 300.00
the pistons around 300.oo the cams around 300.oo when i had
my 103 done the SERT was around 500.00 I think and i cant
rember what the labor was so my guess is going to be around
2000 dollars give or take a few hundred
Old Apr 26, 2011 | 07:33 PM
Mi3ninos's Avatar
Mi3ninos
Wow. When is the last time you looked into these options?
