Fuses for tool kit
Old Apr 29, 2011 | 02:42 AM
Ron750's Avatar
Ron750
Default Fuses for tool kit
Just picked up my 2003 FLHTCUI. I ride in rural area a lot and want to have a good tool kit. So I asked my dealer to give me a good set of spare fuses. All he gave me was 2 15 amp fuses. I have seen posts about 40 amp maxifuse. What fuses do I need to prevent being stuck on side of road? I bought a service manual and haven't read much yet. I assume this info is in there, but thought there must be a bunch of old bikers that know this off the top of their head. Thanks.
Old Apr 29, 2011 | 04:06 AM
Sam2010's Avatar
Sam2010
what I did open fuse box make note what size/kind of fuses in bike. Go to auto parts store buy fuses.
Old Apr 29, 2011 | 05:44 AM
Ron750's Avatar
Ron750
Sounds like a plan. Are all the fuses in the fuse box? Are there remote locations with in line fuses, etc..? Guess I'll do that and check in the manual.
Old Apr 29, 2011 | 05:57 AM
strtarrow's Avatar
strtarrow
The ones in your fuse box should be the only ones unless you have add on stuff such as GPS (can't remember if that has a fuse or not) Gerbing's gear or something similar. I think mine only has 10 and 15 amp fuses but not sure and as I worked all night and drove a hundred miles each way, not gonna check. Easy enough. BTW, they should be under your left side cover.
Old Apr 29, 2011 | 06:09 AM
chevele72's Avatar
chevele72
X2
Your bike doesn't have a Maxi fuse, it has a cicuit breaker. Unless it's been upgraded.
Old Apr 29, 2011 | 06:28 AM
Silverearl's Avatar
Silverearl
There are other fuses, depending on the bike but as for the Maxie fuse if that goes there really is a major problem and I would think that unless you are playing around with the juice then if it blows that is something that just a fuse will not fix. But for the rest of the fuses it is good to have a complete set of fuses.
Old Apr 29, 2011 | 02:10 PM
BBStacker's Avatar
BBStacker
I bought a fuse kit from auto zone took out what the bike needs put em in a an old pill bottle. Overkill but I probably have about 30 in that bottle. Better too many than not enough. Takes up very minimal space.
Old Apr 29, 2011 | 03:00 PM
dbell66253's Avatar
dbell66253
As stated above, see what values and type of fuses your bike has, carry at least 2 of each for a spare, if nothing else use a ziplock bag.
Old Apr 29, 2011 | 07:19 PM
Potato_Potato's Avatar
Potato_Potato
Also there might be some blank spots in the fuse box to keep some spares in.
JU2012FXDWG
Jul 8, 2018 09:55 AM
hapbob
Jun 7, 2018 12:09 PM
voudoujoe
Electrical/Lighting/Alarm
Feb 7, 2012 01:18 PM
BadPiggy
Jan 10, 2008 08:17 PM
GrampsWyatt
Oct 29, 2007 03:03 PM
