front brakes
Old May 7, 2011 | 07:10 AM
aktid35's Avatar
aktid35
Having the same problem on an 07 Roadking, to the point where I tore the entire front end apart, removed the tire, cleaned everything, re-NeverSiezed the axle blake cleaned everything, reinstalled torqued t o specs, noise is still there. Talked to the wrench says its run out on the brake calipers as they kind of "float" and that its normal for harleys, but it damn near sounds like a pad is dragging. Nothing is hot on the rotor or caliper to indicate it is dragging, never did it until a weak ago and I still have plenty of life on the pads. This is driving me CRAZY!
Old May 7, 2011 | 07:31 AM
GAZRNR's Avatar
GAZRNR
Not to hijack the thread but on my 09 ABS when I brake hard with fronts I get aloud HUMMMMMMM. I don't know if you are getting this with the scraping. I only have 11K on the bike and most if it is highway miles.
Nikwho
Oct 14, 2016 01:36 PM
Sid1200
Jun 4, 2015 07:20 PM
steelpony16
Jul 28, 2014 10:05 PM
civilbob
Sep 11, 2012 06:26 PM
Roady65
Wheels/Tires
Jun 19, 2009 08:38 AM
