Wild1 515 and Wire Extensions
Old May 1, 2011 | 09:22 AM
msgtia's Avatar
msgtia
Default Wild1 515 and Wire Extensions
Just ordered the 10" apes from Wild1. Going to have my local HD do the install. John from Wild1 mentioned no reason to replace the cables but mentioned extending the switch wiring. For those of you that swapped for the 515's, did you find that to be the case? Did you get the switch wire extension kit from HD? By the way, have an 011 RKC. Stock bars are driving me crazy.
Old May 1, 2011 | 10:16 AM
Hardcorvette's Avatar
Hardcorvette
I went with the 10" Wild1 Mini Apes as well on my 09' RKC. Wild1 said I would likely need signal extensions, and that turned out to be the case. I purchased an 8" extension from NAMZ. I probably could have gotten by with a 4" extension, but the extra wiring actually makes it easier. I also ran the signal wiring inside the bars, which makes for a much cleaner look.
Rodney54
2014-2024 Touring Models
Sep 30, 2014 06:21 PM
Robtarra39
Jan 2, 2012 06:47 AM
jbied
Feb 16, 2011 08:47 AM
waterproof
Apr 11, 2010 11:31 PM
fcast4
Nov 30, 2006 08:12 AM
