Remap, stage 1 or do nothing
Old May 1, 2011 | 10:08 PM
WNMORE's Avatar
WNMORE
Default Remap, stage 1 or do nothing
I have a 103" engine with the CAT. My dealer told me if I put on a set of slip-ons alone, I will not need any other modifications. So, I put on a set of RC Components slip-ons. The looks and sound are great and the bike runs fine. Nothing else has been done to the exhaust or fuel management.
My question is: When decelerating while I do not hear any "popping" or backfiring, when the rpms fall from 3,000+/- I hear a bit of a rumble at around 2,000 rpms that I do not hear while decelerating through the 3,000 to 2,000 range or at any other rpms. Sometimes the same thing when I rev the engine, but never that "pop-pop" or backfire sound. Does this sound normal, or should I consider a remap, stage 1 or nothing? I am happy with the way the bike runs and am not looking for more performance. And surprisingly, the bike does not run too hot as many have reported here.
Thanks in advance.
Old May 2, 2011 | 05:22 AM
dawg's Avatar
dawg
Normal, you don't need a remap with slips only.
Old May 2, 2011 | 05:54 AM
shari's Avatar
shari
I have the same "rumble" on my 103 and I have slip ons, high flow air filter and a tuner
Old May 2, 2011 | 06:40 AM
Notgrownup's Avatar
Notgrownup
These machines makes some funky sounds sometimes and after a while you get use to them...Have fun with the sounds, be one with the sounds, they will grow on you....
Old May 2, 2011 | 06:47 AM
VETERAN75's Avatar
VETERAN75
The rumble is the one you want, the decel pop is unburned fuel getting to the exhaust then burning. No map required the ecm can accommodate a slip on change.
Old May 2, 2011 | 07:43 AM
jjnoble's Avatar
jjnoble
Normal....You are fine.
Old May 2, 2011 | 08:21 AM
dohadex's Avatar
dohadex
The rumbling/decel popping is normal. If you went with a Power Commander, you can richen up the map in certain areas to decrease that to almost nothing.
I richened the 0% cells from 4000 rpm down to 1500 rpm. Popping is gone.
The Power Comander is really a neat tool when you figure out how to map it correctly. I'm still learning.
Good luck!
Old May 3, 2011 | 04:59 PM
WNMORE's Avatar
WNMORE
Thanks for the replies. The dealer also told me that the sounds are normal and explained that thanks to EPA, on deceleration the fuel cuts out (or back) and the rumble is the remaining bit of fuel in the cylinders burning off.
Thanks again.
Roadster
Milwaukee Eight (M8)
Aug 25, 2017 01:49 PM
Jessie
May 8, 2008 06:15 PM
Big Hog
Jan 12, 2008 11:38 PM
grandpawmoses
Nov 14, 2007 05:09 PM
Snakum
Oct 14, 2007 03:16 PM
