brake noise
Old May 2, 2011 | 06:24 PM
Ghosteh's Avatar
Ghosteh
Default brake noise
My '03 Road King has less than 2,000 miles on it and I've noticed a soft, metallic sound coming from the front caliper as the bike moves. When I just barely apply the front brake, it stops. Now I realize that pads generally "float" on the rotor, but do they really make that much noise? It doesn't see quite right, and is louder than my last bike. Its not a grinding or squealing sound, just like the pad is pressing a little too hard when the brake is off. It rides fine; no issues there.
I'm taking it to the dealer to have them look at that & fix another little issue, but I'm preparing myself for the typical "Its supposed to be like that" answer. Anyone have any insight?
Old May 2, 2011 | 06:35 PM
1Harleyrdr's Avatar
1Harleyrdr
Lots of bikes make that noise, it not unusual. The pads do and will drag to some degree. Is there corrosion on your discs? 3 years imho its time to change the brake fluid too if you aint done so.
Old May 2, 2011 | 06:40 PM
dawg's Avatar
dawg
Clean the pistons as well.
Old May 2, 2011 | 06:41 PM
JohnScrip's Avatar
JohnScrip
If it sounds like a meat slicer, it's normal.
Old May 2, 2011 | 06:47 PM
soos's Avatar
soos
I had the same issue that you described. It was a squeal but when you just barely put pressure on the brake it went away. I pulled the pads out of the caliper and filed a chamfer along the entire outer most vertical edge of both pads and also along the bottom edge of both pads. I reinstalled the pads and the noise went away.
Old May 2, 2011 | 06:50 PM
Glidedsternfan's Avatar
Glidedsternfan
Exclamation 03' - 2000mi?!?!?
Maybe your pads are dry-rotted from lack of use!
Dude! WTF?!?
250 miles per year?
Please tell me you just bought this "low milage cream puff".
Old May 2, 2011 | 06:56 PM
Stiggy's Avatar
Stiggy
Dude! WTF?!?
250 miles per year?
Maybe he meant 20,000....please tell me he meant 20,000!
Old May 5, 2011 | 11:01 AM
Ghosteh's Avatar
Ghosteh
No, I meant 2,000. I bought it in Feb. with 900 miles on it, so don't blame me for the low miles! I'm doing my best to correct that!
Having the brake fluid changed is a good idea. I'll definately do that, along with cleaning the pistons and filing the edge of the pads (good tip!) . I'm sure that nothing is broken, but still it's a very annoying sound & one that my last bike didn't make.
cajun1957a
Jul 7, 2017 03:42 PM
junglejoe
2014-2024 Touring Models
May 10, 2016 12:59 PM
3rdgear
Sep 6, 2009 08:22 PM
JerseyDevil
Oct 3, 2008 09:16 PM
wideglide78
Feb 14, 2008 07:19 PM
