Front brake making noise
randy
randy
randy
I read in another post here in hdfoums a wk or so back that aftermarket non HD brake pads make noise but the formula that that OEM HD brake pads are made of dont make the annoying noise your reffering too.
I just bought front & rear OEM Hd brakes pads for my 09 flhtcu and installed last wk & guess what?
They dont make any noise on the front or rear just like the worn out OEM pads i just replaced so maybe what i read correct.
Surdyke HD online OEM parts sales was running a sale on OEM HD brake pads if you want to try them to see if the noise stops like the post here in hdforums said was " supposedly " the case due to the different formula HD uses for their brake pads.
But even though i dont know for 100% sure the post i read ere stating oem/hD pads were the only ones that dont seem to make noise my 1st hand exp with my 09 flhtcu thats still got it's original disks & calipers with just under 20k miles on the bike is there absolutely no noise from the calipers or disks when braking using OEM HD brake pads which is why i use them.
BTW,@ just shy of 20k miles the rear pas were just thin enough to not lass insp and front pads were approx 65-70% worn out so i said what the heck and replaced both front & rear at same time since the pads were sale.
Was glad i replaced the front pads even though they didnt seem to need it ,but when i got front calipers off i found the inner pads to be worn considerably more then outer pads likely due to dirt/brake dust hanging up pads in calipers along with a lot of dirt on pistons too collectively causing brake pads to not always fully retract off disc when releasing brake handle.
So i removed the oil brake pads from the calipers & cleaned the pistons and calipers in general of all dirt & brake dust prior to pushing /returning the pistons into the calipers.
I also put a little bit of brake grease on the rubber boots on caliper pistons prior to returning /pushing them back into the calipers to accept the new thicker brake pads.
Then i re-installed the brake pads using brake pad grease (sparingly) on contacts points in calipers to ensure they pads would not get hung up.
While i was at it i also flushed/replaced the brake fluid in front & rear brake system too.
I have been thru 2 tanks of fuel since installing the new brake pads on front & rear and installing new brake fluid and all is good thus far with the brakes now stopping the bike considerably better/faster as compared to the worn pads with old brake fluid in the brake system.
BTW,in general prior to installing new brake pads its always good to 1st check the brake fluid lvl and if its full i remove a little brake fluid to ensure the master cyls doesnt get a hyd lock situation or brake fluid leak from the master cyl cover if its full prior to returning/seating the pistons back into the calipers (to accept new thicker brake pads) which backs up/returns brake fluid to master cyl which can in some cases lead to problems.
Then after i install the new brake pads and test the brakes out i then recheck brake fluid lvl & top off if required.
Scott
randy
randy
randy
