Front brake making noise
Old Jun 4, 2016 | 06:42 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Clean your front caliper pistons with brake cleaner spray. To do this, you will need to remove the caliper, remove the pads, replace pads with a 3/8" thick piece of wood, gently pull the front brake lever to extend the pistons until they rest on the wood. Now is when you spray them down real good and clean the road grime off of them. Once cleaned, push the pistons back into a recessed position. Then before reinstalling the pads, ensure you have some grease between the piston and the back of the pads. Torque the calipers back on the legs to spec. This should help if not eliminate your issues. (Note: Do not touch the brake unless the wood or the pads is in both calipers. If you blow out a piston by mistake, it can really screw-up your day.)
Old Jun 4, 2016 | 07:10 PM
mikeo33y's Avatar
mikeo33y
i stopped washing my rotors. no more squeak. i dont know whats in soap but as soon as i stopped washing the rotors it stopped and never cam back
Old Jun 12, 2016 | 07:31 PM
cajun1957a's Avatar
cajun1957a
Still cant find a tool to remove the shoe pins. Looks like a 12 point head no more than 1\4 inch. Harley dealer says its most likely a proprietary tool meaning that only Harley mechanics are privy to it. The tech was off this weekend so he couldn't verify it but it wouldn't surprise me that its that way so you have to take it back to the dealer.
randy
Old Jun 12, 2016 | 08:29 PM
mikeo33y's Avatar
mikeo33y
i thought the shoe/pad pins are a allen bolt
Old Jun 13, 2016 | 12:07 AM
skratch's Avatar
skratch
randy
no special tool needed. there is a pin clip that you remove, then the pad pin will slide right out. might need a slight tap, but you won't have to force it.
replacing brake pads is a simple job that you should be able to do in 1/2hr or less. especially if you have the newer 2 piece caliper on the rear wheel.
Old Jun 13, 2016 | 07:49 AM
cajun1957a's Avatar
cajun1957a
There is no room to put a boxed end wrench or anything for that matter on these. A thin walled 12 point socket is the only thing that will work and no one knows what I'm talking about at the tool stores. The best I can figure out is they are about 7 mm.
randy
Old Jun 13, 2016 | 07:09 PM
skratch's Avatar
skratch
that caliper looks like the one on my 07, ie. pre-brembo. it's been a long time since I did the brakes on my 07, so I've completely forgotten what I used to do the job with. I don't even have my 07 manual anymore either.
good luck, hope you get it figured out sooner rather than later. and please, come back and let us know what you did.
Old Jun 13, 2016 | 07:49 PM
Vzguy's Avatar
Vzguy
I just picked up a 12pt 1/4 thin walled socket for my caliper rebuild from Sears...
http://www.sears.com/craftsman-1-4-i...5&blockType=G5
Perfect Fit..
Old Jun 16, 2016 | 07:00 AM
cajun1957a's Avatar
cajun1957a
Well, I found the tool and went to cleaning up the calipers. As everyone here said, its pretty easy. Pulled the shoes off, they were wearing uneavenly. Slowly extended the pistons. One moved out more than half way before the other did in each caliper. There was virtually no dirt or grime on them, but I did spray brake cleaner all around them and wiped it off. I installed brand new shoes and reassembled and greased the backs. Thewhole process took 30 minutes. Very easy. Went down the road and the noise that I heard is all but gone until pulling the lever and that's all cool. I got home lifted the bike up on a lift and checked to see how the wheel turned. Its rather tight and the rotor was hot. I am really really hopeing these new shoes just need to seat in. So we will see after a few miles. Was easy to do though. Thanks a bunch
randy
Old Jul 7, 2017 | 03:42 PM
K.P RoadKing's Avatar
K.P RoadKing
3rd Gear
Default SAme issue here.
Im having the same issue here on my 07 roadking flhr . makes a hissing noise unless the brakes are slightly engaged let me know if this continually worked for you with no further issue.
junglejoe
2014-2024 Touring Models
May 10, 2016 12:59 PM
Skid Lid
Apr 4, 2012 03:18 PM
Royal271
Aug 26, 2011 09:42 PM
Ghosteh
May 5, 2011 11:01 AM
BohicaAZ
Jan 24, 2010 07:46 PM
