Drilling fiberglass
Old May 3, 2011 | 06:08 PM
K Melancon's Avatar
K Melancon
I was told to run the drill in reverse by a boat rigger. This is to stop the splitting. I have done this several time on thin stuff and it works. Just takes a little longer. It dont work all the time so I think I may need to be a certain type bit and I have a varity.
Old May 3, 2011 | 06:10 PM
MadIrish's Avatar
MadIrish
When drilling some holes in my fiberglass fairing, the maker strongly suggested working up in drill size and using light pressure. After drilling the initial hole from the inside of my fairing to the outside (the only point of reference for what I needed was a mark on the inside surface), I made the successively larger holes from the outside in so that if there was any any raggedness it would wind up on the unseen side.
Old May 3, 2011 | 06:12 PM
frankiefire702's Avatar
frankiefire702
I used regular bits. Worked fine. Thanks guys.
Old May 3, 2011 | 06:34 PM
timberland's Avatar
timberland
From: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
Use a wood centerpoint drill bit up to 3/8" and a hole saw over 3/8", start in reverse until you pass the gelcoat then forward to finish the cut, this eliminates "flaking" of the gelcoat. That is how we mount accessories on fiberglass bass boats.
davidw221
Dec 13, 2021 01:56 PM
Felix 808
2014-2024 Touring Models
Aug 29, 2015 07:42 PM
sfcmo357
Jun 9, 2014 11:38 AM
BlackPearl#1
Sep 2, 2013 04:42 PM
shortleg
May 29, 2012 09:56 PM
