Cam upgrade, the good, the bad and the ugly...
Old May 5, 2011 | 04:34 AM
reese's Avatar
reese
Default Cam upgrade, the good, the bad and the ugly...
Well, got the 555's in and just got it off of the Dyno. Numbers are low but it definitely runs stronger. 89HP, 90TQ with a long torque curve and HP rising all of the way through to 6200. They said there were some issues with the Dyno so that could be where the low numbers are coming from. I might have it Dyno'd elsewhere later to see if that can be bettered.
Here's the ugly. The bike has developed a deep sounding knock between 1500 - 2000 RPM. You mainly hear it when taking off slowly. Anyone else experience this or know what that sound could be ? My mind is telling me to remove and replace the pipes with new gaskets for some reason... but I can't feel or hear any exhaust leak when next to the bike. This knock kicked in as soon as we fired it up and test rode it after the cam install, I was hoping the Dyno would resolve it but it didn't.
Old May 5, 2011 | 04:41 AM
HD101st's Avatar
HD101st
the knock if i was to take a shot is probally coming from the valve train or rocker boxes depending on your cam choice pushrods may not be adjusted to spec, valve springs could be hung up. Usually noises that were not there before can be contributed to the last change you made which in your case maybe the cams i would start there.
Old May 5, 2011 | 09:03 AM
equandt's Avatar
equandt
A dyno is simply a tuning tool. Not all dynos are calibrated the same and not all dyno operators run the dyno the same. With that said, dyno numbers can vary. Don't get too hung up on the peak numbers (high or low). If your A/F is good throughout the run and the bike runs good with no flat spots you should be good to go.
Posting up big dyno numbers is really just about bragging rights, but riding a well tuned, well running bike is so much better than showing everyone your piece of paper that says 100hp.
I agree with the post above, you probably have some valvetrain noise. If it bugs you, you might want to adjust your pushrods a little, assuming you put in the adjustables. There are lots of DIY write ups on how to do this.
Enjoy what you got. It looks like you have a nice bike there.
Old May 5, 2011 | 10:30 AM
SDVmnt's Avatar
SDVmnt
What exhaust do you have?? Reason I ask. I have a 2010 with the 2 into 1. After installing the SE255 cams and removing the Cat in the headpipe, I had what sounded like physical knocking on the exhaust. Not a ping, but like drumsticks on the side of a snare drum but deeper. At a very specific rpm range too. Right before the power comes on between 2500-3000. Had numerous mechanics ride it but nobody thought anything was wrong. I had a hunch it was the cat chamber I created by removing the cat.
Changed to V&H Power Duals and the noise is gone. Something with the cam and the duration causing the extra compression noise. It was so annoying that I strongly recommend not removing the cat in the 2010 2 into 1's. I don't know for certain but I'm betting the 2 into 2's have the same style cat. Just get different exhaust.
Old May 5, 2011 | 11:03 AM
phattey's Avatar
phattey
[quote=reese;8279503]Well, got the 555's in and just got it off of the Dyno. Numbers are low but it definitely runs stronger. 89HP, 90TQ with a long torque curve and HP rising all of the way through to 6200.
I also had the same experience. Lower numbers than expected, but the bikes running better than ever and pulls great...cooler too. Is your bike a 103 or 96..?
I quit chasing numbers a long time ago, but sometimes when they're MUCH lower than others with similar setups you gotta ask questions. As far as the knock you mention, I can't imagine what that could be.
Did you use adjustable pushrods..? And if so are they set up right..?
Old May 5, 2011 | 11:35 AM
bikehe's Avatar
bikehe
Thats exactly the sound and symtoms I'm getting in the same rpm range after doing my cams. Very annoying, thanks for sharing. Sorry OP for going off track.
Old May 5, 2011 | 11:37 AM
user 8373900's Avatar
user 8373900
1st check your exhaust for clearance especially at the right floorboard, and anywhere close to the frame. 2nd, with your extra torque,(I think your numbers are wrong, you are likely making more), your compensator is bottoming out,my 07 got much worse and I had a S/E comp waiting to put in when I traded.
Mark
Old May 5, 2011 | 11:46 AM
ngoti8tor's Avatar
ngoti8tor
The dyno only reads, it doesn't cure anything.
It sounds like you need to adjust the pushrods. Detonation may be occurring at the wrong time according to where your valves are at during a certain RPM.
Old May 5, 2011 | 05:14 PM
reese's Avatar
reese
My Indy put the cam in, I was just the grunt pulling the exaust and fetching tools... I've worked on Pans and Shovels but have never been in a Twin Cam before, figured I'd better let a professional do it. Screaming Eagle adjustables, set per instructions at 2-1/2 turns off of TDC compression stroke each cylinder. I had to back the bike out of the garage to do something when I got home so I just looked at the exhaust and nothing seems to be hitting. When I fired it up to pull it back into the garage I held the brake and twisted the grip slowly and yep there it is. Sounds like a deep ignition / timing / fuel knock. It's not the pushrods / lifters, I know that sound from the solids on the Pans I owned and at initial fire up that noise was present until the oil pressure came up then all noise got quite like it should.
I think I'll call Mr. Woods tomorrow and see what he says.
Old May 5, 2011 | 05:24 PM
cuda67bnl's Avatar
cuda67bnl
loose baffle rattling in the pipe?
