Tour Pak Turn Signal/Brake light conversin cable - Part # 69200042A
Old May 11, 2011 | 07:05 AM
Mikekoz13's Avatar
Mikekoz13
Default Tour Pak Turn Signal/Brake light conversion cable - Part # 69200042A
I installed this cable this past weekend. It turns the corner lamps on the Tour Pak into turn sigals and brake lights.
It was an easy install (about 40 minutes) and it was all plug and play. The hardest part was getting the Tour Pak liner back in properly!
Works great and just makes the Bike that much more visible.
Old May 11, 2011 | 07:12 AM
ULTRA Gramps's Avatar
ULTRA Gramps
What was cost for the cable?
Old May 11, 2011 | 07:15 AM
Bodean46's Avatar
Bodean46
I bought mine for 58.00 from Michigan City In. dealer. Hardest mpart for me was getting the grommet back in the hole, lol.
Old May 11, 2011 | 07:17 AM
Mikekoz13's Avatar
Mikekoz13
$55......... and yes, the grommet is a little tricky........ took about a minute to force it thru that little hole!
Old May 11, 2011 | 07:20 AM
road_king_rob's Avatar
road_king_rob
Sounds like a great idea. Does this interfere with the detachable tour pack cables, or can it be easily removed when taking the tour pack off?
Old May 11, 2011 | 07:30 AM
Mikekoz13's Avatar
Mikekoz13
It plugs in under the seat in two places. I think you will just be able to disconnect those two cables (and maybe reconnect the stock connectors together so the stock turn signals work??) and be good to go.
Not sure about htis though so check it out before buying.
Old May 11, 2011 | 07:43 AM
vtwinbob's Avatar
vtwinbob
i was also looking at doing this, on my 10 ultra the corner lights on my T/P are running and braking, no turn signal, i noticed you mentioned braking and turn signal on yours, did you not have the braking signal before the cable?
Old May 11, 2011 | 08:30 AM
Harleypingman's Avatar
Harleypingman
Here's a write-up with pictures of the installation of the kit (not sure of the difference between the first version of the kit and the OP's "A" version; HD changes p/n's for reasons that aren't always obvious):
https://www.hdforums.com/forum/touri...rsion-kit.html
It's easy to remove the tour pak by disconnecting a single electrical connector under the seat.
ridetimetechnology offers a product that does the same thing as the HD kit, and also has one for the side marker lights.
Carl
Old Jul 5, 2011 | 11:43 PM
rwhite1357's Avatar
rwhite1357
Stage II
Question Do your Turn Signals Stay on in Accessory Mode?
I had this installed on my 2011 Limited along with the Run/Turn signal kit at the dealer. The dealer is now out of business. The thing that bugs me, my rear red turn signals come on when I turn the ignition switch to accessory. The headlight is off, the front turn signals a are off, but the rear come in as I said. Any ideas? I don't think it should be that way.
Please check and see if yours does that.
Old Aug 24, 2011 | 06:59 PM
silentsrfr's Avatar
silentsrfr
Stage III
Default Turn signals stay on in accessory position.
Mine stay on also in accessory mode. Typical Harley with nothing standard year to year. Gonna take the kit back and get a custom dynamics set up. Their set up is much better and the LEDS are easier to see.
