Sparkplug replacement frequency
Old May 12, 2011 | 12:12 PM
JokerJ13's Avatar
JokerJ13
Originally Posted by Northside
If the electrode isn't worn and the gap is good why change out a perfectly good plug?
Agreed, I check mine every 5-7K and if needed replace them. Otherwise I clean them off and put them back in.
Old May 12, 2011 | 01:32 PM
jjnoble's Avatar
jjnoble
I cleaned mine at 10k and replaced them at 20k. I didn't need to replace them but I was going on a long trip so I did it anyway. Replacing at 5k......no way.
Old May 14, 2011 | 07:36 AM
Rider98Glide's Avatar
Rider98Glide
Default Is it worth the extra $?
Is the extra cost worth spending on a high performance plugs and wires? Does it make a noticeable difference?
'98 FLHTCUI Which ones?
Thanks!
Old May 14, 2011 | 08:09 AM
MareRider's Avatar
MareRider
Originally Posted by sargek
10K which for me is about once a year. I always put on a tad bit of anti-sieze as well to make removal easy next time.
A Buddy just out of MMI told me to be sure to use the gold (copper) colored & NOT the silver (aluminum) colored anti-sieze on them.
Old May 14, 2011 | 08:16 AM
1flhtk4me's Avatar
1flhtk4me
Why?
I have been using Permatex(silver) for a long time,have not seen any problems.
Old May 14, 2011 | 08:17 AM
spider14043's Avatar
spider14043
I use iridium plugs in all my bikes and never replace them. 2010 EGC with 21,000mi.
Old May 14, 2011 | 08:30 AM
MareRider's Avatar
MareRider
Originally Posted by 1flhtk4me
Why?
Dunno, just what he said. If you're changing at regular intervals it's probably not an issue. If they stay in for years though it might be a problem...
He graduated from MMI, but he's just now enrolled in the school of hard knocks... Helped me with my cam install & didn't get the pipes tight enough in the head and had exhaust leaks front & back. They covered that kind of stuff in class, but the bikes that were worked on stayed in the class & didn't get ridden.
I still have the silver anti-sieze on my garage shelf FWIW.
Old May 14, 2011 | 08:48 AM
FLHTCU Owner's Avatar
FLHTCU Owner
I guess I go the other way. It's such an inexpensive part, why not change them out? I do that with my smaller engines as well. I would just rather change them out and know that it's going to carry me through the season. Personal preference is all.
Old May 14, 2011 | 09:01 AM
HRLYSG's Avatar
HRLYSG
I replace them every spring when servicing the bike. For a few bucks, I'm not worried about life span. Plus, they look purdy when new.
Old May 14, 2011 | 10:18 AM
mrmud4x4's Avatar
mrmud4x4
I think it has something to do with the aluminum based anti-sieze getting in the piston chamber. I know when I worked in the power plant...copper was not to be used on steam valve bolts because of potential reaction with steam and superheated steam.
I don't use any.....just don't cross thread, never had a problem. I don't want any metal getting in my piston chambers.
