Sparkplug replacement frequency
Old May 14, 2011 | 06:00 PM
  #51
mrmud4x4's Avatar
mrmud4x4
like I said...you want to use it ....fine.... I really am ok with that...
The 2002 Harley manual does not include adding anti seize....the spark plug companies recommend not using anti seize....anti seize does affect torque values and it does have negative reactionary characteristics when used in different processes...IE....fire/pressure/steam
the above statements are true but.....
Maybe Harley has improved the process of the manufacture of the cylinder heads that a small amount in there is of no concern.
your right on the graphite....still don't want it in my cylinders.
I was taught not to use anti seize in certain applications - spark plugs being one of them - that's all.
Old May 14, 2011 | 06:43 PM
  #52
mrmud4x4's Avatar
mrmud4x4
Originally Posted by Copyless
Man I didn't know I was going to come back to all this rigamarole.
I thought this is what forums were for?
(especially on a nasty rainy day when I can't ride.....lol)
please, don't take my posts personal...just exchange of info...
Old May 14, 2011 | 06:58 PM
  #53
iwillfixthem4u's Avatar
iwillfixthem4u
The 2010 maual states on page 1-42; Apply a light coat of Silver Grade Anti-Seize (part #98960-97)to the spark plug threads. Install and tighten to 12-18 ft-lbs
Old May 14, 2011 | 07:00 PM
  #54
Potato_Potato's Avatar
Potato_Potato
Originally Posted by MareRider
A Buddy just out of MMI told me to be sure to use the gold (copper) colored & NOT the silver (aluminum) colored anti-sieze on them.
Why is that?
Old May 14, 2011 | 07:06 PM
  #55
iwillfixthem4u
this is what I have used in the past. It specifies for use on spark plugs on the bottle. Not sure it it is Silver grade or not.
PermatexŽ Anti-Seize Lubricant
A highly refined blend of aluminum, copper and graphite lubricants. Use during assembly to prevent galling, corrosion and seizing and to assure easier disassembly. Temperature range: -60°F to 1600°F (-51°Cto 871°C). Salt, corrosion and moisture resistant – ideal for marine use. Non-aerosol version meets Mil Spec #907E. Aerosol - Level 3*
This is what Harley calls for:
LoctiteŽ Silver Grade Anti-Seize
Heavy-duty, metal-free anti-seize formulation protects metal parts from rust, corrosion, galling and seizing. Anti-Seize eases disassembly of slip fit, press fit and threaded joints, and provides outstanding lubrication to all metals including stainless steel, aluminum, and soft metals. Withstands temperatures up to 1600°F. Semi-solid stick for easy application.
20 gm. Stick Applicator
Universal.
MSRP US $6.95
Last edited by iwillfixthem4u; May 14, 2011 at 07:15 PM. Reason: information that I pasted did not come out right
Old May 14, 2011 | 07:33 PM
  #56
mrmud4x4's Avatar
mrmud4x4
what does the 05 manual state?....the 02 manual does not include using anti seize in the spark plug change procedure. Page 1-28 service manual.
anybody have an 05 manual?
Old May 14, 2011 | 08:09 PM
  #57
mrmud4x4's Avatar
mrmud4x4
Universal.
MSRP US $6.95
ok....got anything new to add to the conversation except an anti seize ad?
Old May 14, 2011 | 08:39 PM
  #58
jayray's Avatar
jayray
I carry a set, in case I or someone else need them. I like those SE red wires. There is a crush washer that needs only to be used once.....
Old May 14, 2011 | 08:43 PM
  #59
upstate tim's Avatar
upstate tim
Put a plug in it...
Lol
Old May 15, 2011 | 07:00 AM
  #60
Route66rider's Avatar
Route66rider
WOW! Way back when I originally asked about plug replacement frequency it was a random question due to the fact the rear plug (iridium sp?) was as bad as it was after just 9 months or so. I did not know it would generate into this wealth of information.
Anyway, thanks & I did replace them with standard Autolite plugs and will most likely do so again.
(Oh, and I did use a small amount of the gray anti-seeze as I have a bottle of it that will likely out last my grandchildren....)
