Said Goodbye to the King and Hello to the Street Glide.....
I removed my SE AIr Cleaner, Pipes and PC-V from the king and would like to move them to my Street Glide. I damaged one of the o2 eliminators when removing it from the King. Dynajet's instructions do not list them or discuss installing them on the 2010-2011 bikes. Are they no longer needed? I know I need to update the firmware/Map on the PC-V and plan on purchasing a 2-1-2 headpipe from Fuel Moto. I assume that everything else installs the same was as on my 09 King?
I will ride the bike 500 miles to break it in and then make the changes.
If you were running the PCV with out AT, you don't need the 02 sensors. You should have replaced them with a jumper. If you had AutoTune sensors, also called wide band sensors you would need them to run AT. But you could run without sensors.
If you run without the sensors, make sure you use the jumpers in place of them.
