headpipes
Old May 14, 2011 | 07:11 PM
tuffenuff's Avatar
tuffenuff
6th Gear
Default headpipes
got an '11 FLHTK. Headpipes have cats? A friend has a set of headpipes off '09 streetglide w/o cats. does anyone know if they will bolt up and work?
Old May 14, 2011 | 07:17 PM
JRBass's Avatar
JRBass
They will bolt right up and work just fine... However the O2 sensor bung hole size and location is different on the 09 to the 11. You will have to either weld in new bungs and plug the old ones or go with a tuner that doesn't use the O2 sensors or has Autotune like the PCV has.
Old May 14, 2011 | 07:18 PM
dawg's Avatar
dawg
Your 11 has cats. The difference between the two pipes is that the 02 sensors are different and different locations. You would have to do some modding.
Old May 14, 2011 | 07:21 PM
tuffenuff's Avatar
tuffenuff
6th Gear
thank you for the quick responses will have to match up and see there they fall
Old May 14, 2011 | 07:49 PM
coolerman69's Avatar
coolerman69
why not just gut the cat outta your pipes?
Old May 14, 2011 | 08:19 PM
Loco Lucas's Avatar
Loco Lucas
3rd Gear
I am considering doing this myself. Can anyone from the bay area recomend a good shop to have this done at? also what price to expect.
Old May 15, 2011 | 01:13 AM
JohnScrip's Avatar
JohnScrip
Keep in mind that the typical shop won't touch this (it's not exactly "Kosher" if you catch my drift). And keep in mind that if you're in an area where you're emission-tested, you're going to wind up out of compliance.
mking7
Oct 11, 2011 10:41 AM
Vivid Glide 103
Jun 22, 2011 04:33 PM
HOGDAT
Mar 21, 2011 06:56 AM
slothy
Jan 17, 2011 09:39 AM
BLKnCHRME09Deluxe
Aug 22, 2010 09:12 AM
