run stop turn module problem
Old May 14, 2011 | 08:28 PM
legionofosiris's Avatar
legionofosiris
3rd Gear
Default run stop turn module problem
I just installed boom audio (windshield mounted) and run stop turn module on my 2010 RKC. Audio sounds great but rear lights just stay on. They are bright and turn signals work correctly but they dont even blink when I apply breaks. I just plugged in the module. Do I need new turn signal bulbs (different than stock) or am I over looking something basic? Any suggestions? the break light doesnt even blink after I took off the module but it was fine before, did I do something wrong?
Old May 14, 2011 | 08:33 PM
Jackie Paper's Avatar
Jackie Paper
With in the last few weeks someone posted with similar problems. Do a search. Think he had the wrong part number do to an error of mislabeled parts at the factory. Someone actually contacted him from high up in Harley about it. Think you are saying after removing it you have a light problem now. Check your fuses. Accessory fuse for sure. The part if incorrect shorted straight to ground.
Old May 14, 2011 | 08:34 PM
roadgliderick's Avatar
roadgliderick
check your accesory fuse.
Old May 14, 2011 | 08:39 PM
legionofosiris
3rd Gear
thanks. I have been searching for similar and haven't found anything that helps. I will check part number. Do you happen to remember the name of the thread?
Old May 15, 2011 | 02:18 PM
legionofosiris
3rd Gear
checked fuse-fuse is fine. man I hate messing with electrical.
Jmartinlfd
Jun 2, 2013 09:52 PM
blkonblk17
May 21, 2013 05:59 PM
mimo
Mar 13, 2009 08:43 PM
KENNYPOCONOS
Nov 12, 2008 11:31 AM
Matrix
May 29, 2007 10:47 PM
