Jack placement question
Old Jul 16, 2005 | 04:09 PM
HDF Tech's Avatar
HDF Tech
Default RE: Jack placement question
A little trick I learned is 2 dots of white paint on the lift arms. One tells you how far you push the lift in and the other (usually on the cross brace between the lift arms) I use as a reference point like to line up with a seam in the heat shield. This can be done after you find the correct balancing on the lift , then just lower it down till the wheels are almost supporting the load but not entirely so you can get an accurate mark on the lift arms.
It takes all the constant guess work out of it each time you use the lift.
Old Jul 17, 2005 | 11:46 AM
ochog's Avatar
ochog
Thanks guys, great tips!
Old Jul 17, 2005 | 04:41 PM
hogsolo16's Avatar
hogsolo16
I bring mine in from the opp side of stand then i hold the bike streight up then lift it , works great
Wulf
Aug 13, 2013 06:46 PM
Hrod
Sep 8, 2010 11:57 AM
Nightster Ridester
Dec 31, 2009 09:52 AM
harley-jones
Oct 14, 2008 03:36 PM
jeb_cfl
Dec 25, 2007 05:27 PM
