Can anybody tell me the procedure for resetting the ECM? I think it is: turn on run switch and cycle the ignition switch 4 times with 10 seconds between each cyle? or maybe 4 seconds?? I put in a new fuel management device and someone recommended I reset eveything. Thanks
PCV 5 with Jamies map. Hoping to finally take my first ride Sunday with a few hour break in the rain planned? Since I've been firing her on and off in the garage and not riding, I was told by someone whos suppose to know, to recycle the ECM? Thanks
You should be able to hook a lap top too it while running at normal operating temp with the PCV software and it will show you throttle percentage and temp and rpm and stuff. It needs to be at 175 degrees or more then the throttle should read 0 percent.
PS. whatch the usb cable and the exhaust.. Ask me how I know.
