Cam Chain Tensioners
Old May 21, 2011 | 07:51 AM
KDUBYA's Avatar
KDUBYA
Default Cam Chain Tensioners
When do I need to start thinking about cam chain tensioners? I have heard different people having them fail anywhere from 15 to 60 thousand miles. To anyone that has replaced them, did you stay with the Factory parts or aftermarket? Do you just change the tensioner or gears and chain too? Anyone using gear drive and which do you like better? Are gear drives noisy? Anything else I need to know??
Old May 21, 2011 | 07:58 AM
05ROADGLIDE's Avatar
05ROADGLIDE
What year is your bike?
Old May 21, 2011 | 08:05 AM
69cj's Avatar
69cj
His sig says 2007!
Old May 21, 2011 | 08:10 AM
SpiderPig's Avatar
SpiderPig
If you are changing just the tensioners then the only option is the HD replacement parts. There is a new updated hydraulic set up that is the way to go. Now if you want to go to gear drive, and be done with it, and to answer your question you can. But need to make sure your crank run out is within spec and IF set up properly you will not have but the slightest "whine or whirring" noise. Which I thinks sounds good as I have them in my 06.
Old May 21, 2011 | 08:11 AM
05ROADGLIDE
Originally Posted by 69cj
His sig says 2007!
Sorry on a iPhone can't see the sigs. Anyway 2007 up have the new upgraded hydraulic cam tensioners. Don't have to worry about the old spring loaded ones. Just as good as gear drive and quieter.
Bodean46's Avatar
Bodean46
Did mine at 13000. Went gear drive and haven't really noticed an more noise than usual. Had an exhaust lifter collapsed and tensioners were 50% wore so for piece of mind made the change. The new hydraulic upgrade was not available or may have went that way.
Old May 21, 2011 | 08:17 AM
2009blackpearle's Avatar
2009blackpearle
Default mine wore a bit in 12000 mile
I had 19000 km which justyt under 12000 mile when i did a engine upgrade and the outer shoe had small lines in it. the inner cam shoe was fine. I just finshed the winter build up on my motor this winter, 2 winter build up and replaced my compensator at 35000 km or 22000 miles and my shoe for the primary was stsrting to wear, i replaced it since I was in there. think the cam show was $45 usa and primary was $93 usa. I live on border so i get part in usa since they are marked up way to hiigh in can.
Old May 21, 2011 | 08:42 AM
relli's Avatar
relli
75k with synthetic mine are like new
Danburnsart
Nov 12, 2013 02:09 PM
Mikey 1450
Dec 23, 2010 08:05 AM
BLACKTOP GLIDER
Apr 3, 2010 06:03 PM
jurgie
Mar 2, 2010 08:06 PM
Sayang
Oct 20, 2009 01:23 PM
