A Little Help Removing the Trap Door Please
Old May 27, 2011 | 08:28 PM
Snowfly's Avatar
Snowfly
Default A Little Help Removing the Trap Door Please
I'm installing a screaming eagle 6 speed (33137-04) in my 05 Ultra. I need to remove the trap door to repair a couple of damaged bolt threads at the bottom of the trap door, the 5/16 x 18 bolts that hold the exhaust bracket onto the trap door. My "05" service manual says to remove the shifter forks. The center one comes right out but I'm having a problem removing the two outer ones. The one closest to the primary looks like it lays low enough to clear the case but the one closest to the trap door looks like it is to high to clear the case. Do they need to come out and if so what is the best way to do this. Thanks
Old May 27, 2011 | 10:07 PM
Snowfly's Avatar
Snowfly
I got it out. I didn't need to remove the outer shifter forks. There wasn't much clearance, but just enough.
Bountyhunterboba
Nov 12, 2013 03:58 PM
Chris Burdette
Aug 11, 2012 12:43 PM
Twizted
13
Feb 4, 2011 12:48 AM
ny06fxdb
Jul 9, 2007 03:52 PM
dsuppa
Jan 11, 2007 10:26 PM
