help with shifter arm replacement '03 FXDP
Old Aug 10, 2012 | 04:29 PM
Chris Burdette's Avatar
Chris Burdette
Stage IV
Default help with shifter arm replacement '03 FXDP
I am new to the DIY on my bike. The aluminum shifter arm that attaches to the shaft coming out of the trans needs replacing. It appears I must remove the primary cover to even get near it. Are there any special tools I will need to pull gears or anything else?
Old Aug 10, 2012 | 04:50 PM
Chris Burdette
Stage IV
It appears I have to remove the floorboard, heel/toe shifter, outer cover, both sprockets and chain, and then the inner cover just to remove the arm.
Old Aug 10, 2012 | 06:13 PM
maddghost's Avatar
maddghost
sounds about right. it only takes an experienced Harley tek one hour to remove those parts and slap em back together. most important tool I think is a bar that locks the clutch basket against the front sprocket and once the bolt is loose the basket comes right out. It may sound easy put that way, but I know it take me way more time than that.
Old Aug 10, 2012 | 07:55 PM
DanDman's Avatar
DanDman
There is after market arm that replaces the stock one. It clamps on with 2 or 4. You don't have to remove the. primary to install it. The old one is cut off with dremel tool. When I remember the mfg. I'll post it
Old Aug 10, 2012 | 07:56 PM
DanDman's Avatar
DanDman
2 or 4 bolts.
Old Aug 10, 2012 | 08:16 PM
Uncle Larry's Avatar
Uncle Larry
This will help you ...
http://betterlever.com/how_to.php
Old Aug 11, 2012 | 01:58 AM
DanDman's Avatar
DanDman
That's it. Thnx Uncle Larry
Old Aug 11, 2012 | 09:50 AM
M&P340's Avatar
M&P340
Yep, you're right. I have an '04 FXDP that I recently replaced the shifter shaft seal on, and the floorboards, outer primary cover, comp sprocket, clutch basket & chain, front drive pulley, and inner primary case all have to come off to get to the shifter arm attached to the extention. Also, the two bolts that attach the starter to the inner primary case must be removed. It's a pretty big job unless you're an experienced tech.
You do need some unusual tools including a big socket for comp sprocket nut (can't recall size, 1 1/2" maybe?) and it is rt-hand treaded, big socket for the clutch basket nut (I used 30mm) and it is lt-hand thread, and something to lock the comp sprocket/clutch basket sos you can get them off. I fabbed up a tool from 1/4" steel bar that is 10.5" long, 2" wide, with a 1.75" slot cut out of one end to make clearance for clutch basket starter gear.
Don't know how many miles are on your bike, but since you are inside anyway, might consider replacing the inner primary seal, shifter seal, 5th gear seal, & quad seal. It's a big pain going in when they leak, as mine did (inner primary bearing race walked dumping entire primary lube load in about 5 miles).
Good luck. You really need a HD service manual. And the torque spec for the clutch basket nut in the manual is no longer correct. New torque procedure issued later in serv bulletin.
Old Aug 11, 2012 | 11:39 AM
Chris Burdette
Stage IV
Thanks to everyone who posted. I took the heel/toe shifter, floorboard and outer cover off. I found Jack Schitt's asian cousin Ho Lee Schitt inside the primary cover. Then I checked this forum thread. Thanks to DanDMan and Uncle Larry for the link. I think that is how I am going to finish this job. Ah well, the chain needed adjusting and the fluid needed replacing anyway. I don't have specialty tools, but I do have the shop manual. ride safe and thank you all!
Old Aug 11, 2012 | 12:43 PM
Chris Burdette
Stage IV
...and then I saw the price. The replacement part from Drag Specialties is $30 conpared to $200. I guess I get to learn how to disassemble and reassemble my primary. I have 35k miles on it so replacing the seals is probably not a bad idea.
brino
EVO
Sep 14, 2011 05:58 PM
Twizted
13
Feb 4, 2011 12:48 AM
mrtac2man
Sep 8, 2010 06:39 PM
lowrider8898
Oil Archive (no new posts)
Jun 6, 2009 11:48 PM
southernknight8
Jan 9, 2009 07:36 PM
