Bent Mainshaft!
Old May 28, 2011 | 04:01 AM
twowheelsgood's Avatar
twowheelsgood
Default Bent Mainshaft!
I have a 1999 Roadking with 30k miles.
Was coming home from work and after a few miles noticed that the engine was losing power and that it wanted to stall at idle.
I also noticed (later) a metalic knocking noise coming from the primary.
Well, it turns out that the transmission mainshaft is bent- maybe 1/4" out of true...The clutch basket and chain were hitting the inner wall of the primary causing the noise and friction.
Has this happened to anyone else? How..?.. we were just doing our usual ride through the city to get home!
Any ideas about what might be the cause?
What needs to be replaced, typically, mainshaft, bearing?
Really appreciate everyones help and experience on the forum!
Thanks
TWG
Old May 28, 2011 | 06:08 AM
cdestuck's Avatar
cdestuck
Dang, wierd how that could just happen without an incident. Cant tell you for sure what needs replaced, but when in doubt, for sure any inexpensive part would get replaced just to make sure. If your going to all the trouble to open it up, just a bit of cheap insurance to do any bearing you can get close to.
Just was wondering if the problem might have been a semi defective shaft. Good enough to go 30000 miles but not good enough to hit 31000. Sure you'll get some better answers than mine here. good luck.
Old May 28, 2011 | 06:16 AM
Stiggy's Avatar
Stiggy
I suspect that you had a bad bearing which in turn bent the shaft. Hopefully that will be all you'll have to replace, plus incidentals.
Old May 28, 2011 | 06:51 AM
twowheelsgood
yeah - very strange - will check the bearing once I get it all dissassembled...
There was no accident or bump or anything at all just a happy transmission when I left work and a useless one when I got home.
Anyone else ever had this problem?
Old May 28, 2011 | 08:39 AM
1931jamesw's Avatar
1931jamesw
PM sent.
Old May 28, 2011 | 08:46 AM
Zimbob's Avatar
Zimbob
My '07 had a main bearing take a dump at 32K+, took out the races too, didn't hurt the shaft any as I could tell.
Old May 28, 2011 | 01:02 PM
Beeracuda's Avatar
Beeracuda
Here's what happened to mine. https://www.hdforums.com/forum/touring-models/640391-main-shaft.html
I just got the bike going yesterday. I bought a gear set with 2800 miles on it for $150.00 on ebay. I changed the drive belt while I was at it.
Old May 28, 2011 | 01:05 PM
Beeracuda's Avatar
Beeracuda
Old May 28, 2011 | 02:05 PM
Guntoter's Avatar
Guntoter
Years ago I had bought a basket case 1975 Sportster that the transmission (and many other things) were in need of repair. In the trans, first gear had broken a tooth off and the owner just kept riding it, but not using first gear, until it went "bang". That gear tooth had finally got picked up by another gear which tried to mash it it between 2 gears. In addition to a broken trapdoor, it bent the countershaft.
My guess is that something similar may have happened, or a bearing came apart inside the transmission allowing the mainshaft to wallow all over.
Old May 29, 2011 | 10:25 AM
twowheelsgood
wow - thanks for all the responses.
This is an odd failure
The gears are fine. We took the top cover off and its clear that the gears look perfect.
Had to buy a mainshaft nut removal tool from ebay - it arrives next week so we will see how it all looks after that.
Don't know if the bearing has failed and if this has wither allowed a straight mainshaft to move or has resulted in a bent mainshaft. The bearings are probably ok - I kinda hope so cause I dont want to have to buy the bearing removal tool! ... but wont really be able to tell until I get the tranny out.
Very unexpected failure - this isnt a big inch motor 100% stock with only a stage 1 airbox/dynoject upgrade...I even have stock mufflers on it.
Now I guess it's time to find a replacement mainshaft or gearset.
Thx
TWG
