Stator is Fried
Old May 28, 2011 | 07:57 AM
masterblaster's Avatar
masterblaster
Default Stator is Fried
I just changed primary oil again, battery dead, pimary oil is dirty again(3rd time in week), with more metal chips. I am guessing stator.
Old May 28, 2011 | 09:01 AM
69cj's Avatar
69cj
You might want to tear it down before that metal takes anything else out such as the main shaft bearing or clutch plates. While it's apart, good time for an S.E. compensator and clutch diaphram spring.
Old May 28, 2011 | 09:08 AM
joe98's Avatar
joe98
Master, sorrry to hear about your bad luck. I'm not a wrench by no means, and this is just a guess/long shot. On my 08 SG, last summer I had primary fluid leaking into the starter. I was about 1,200 miles from home and the guy who we were staying with actually worked at the HD dealer. Not a wrench but worked in parts. He assumed it was just a primary seal, because of where the oil was dripping. Down the belt guard and under that area. Anyways, when I got home, I took it into to my local Indy and what a surprise. The starter was just blacker than a dead seagull from an oil spill. Just filled with oil. The Indy was amazed that I didn't fry the starter or break down on the side of the road. It was all covered under warr. but I never would of thought it could have been the starter seal, allowing the fluid to enter the cavity. Hope this helps dude...Good luck.
Old May 28, 2011 | 09:53 AM
masterblaster
I am tearin into it now,I have the SE COMP and the SE spring (before I pick up new bike I have them put new med SE spring in). Will check clutch though.
Old May 28, 2011 | 10:39 AM
cp1's Avatar
cp1
If it is the stator when you replace it check and make sure all of your grounds are clean, especially at the voltage regulator.
Old May 28, 2011 | 10:52 AM
dbell66253's Avatar
dbell66253
I kind of remember metioning the stator on the other thread, hmmmm...well, I hope that fixes your problem and everything works out ok. BTW how did that cam install go last week?
Old May 28, 2011 | 12:17 PM
masterblaster
Yeah ya did and you were right, its fried. Cam install went well, I like this cam a lot. I like the whole FM 107 with 54 cam Bigboyz heads combo.
Only thingI might change is the Bub 7 2-1, sounds nice but giving up some low end grunt.
Old May 28, 2011 | 10:17 PM
iclick's Avatar
iclick
Unless it's already installed, I would not opt for the SE spring. It will stiffen your clutch operation considerably and you likely don't need it unless you have a build substantially stronger than stock. Fuel Moto's 107 kits don't even require a spring change according to them.
Bingee
13
Aug 8, 2021 09:43 AM
Scorpio09SG
Jul 24, 2015 03:58 PM
Jerry Battershell
Nov 22, 2013 10:19 AM
HarleyLarryM
Oil Archive (no new posts)
Dec 19, 2012 09:37 AM
titusvilleharley
Oct 11, 2008 10:10 AM
