Screaming eagle clutch
Old May 28, 2011 | 05:39 PM
ride03harley's Avatar
ride03harley
Stage II
Default Screaming eagle clutch
How do you remove screaming eagle clutch hub , I'm trying to replace the stator. I tried to lower the rear tire on to the ground and loosen the bolt and no luck
Old May 28, 2011 | 06:06 PM
07RoadHawg's Avatar
07RoadHawg
You need to use locking device of some sort between the compensator and clutch basket to keep it from moving. I've used a couple of red shop rags knotted up before, but the metal bar as shown in the service manual is ideal.
And just incase, lefty is not loosey... left hand thread on the clutch, right hand thread on the compensator.
Old May 28, 2011 | 07:11 PM
18BKLR's Avatar
18BKLR
Exactly right. Make a bar from some stock 1/4" flat bar. Round the edges off. I think its 5 and 7/8's or something. Not sure though. I am thinking the measurement is in the book. If not let me know and I will measure the one that I made.
Old May 29, 2011 | 08:45 AM
2009blackpearle's Avatar
2009blackpearle
Default dont take off the clucth hub
there is a alot easier way than taking the entire clutch apart and the inner primary as harley says. the raised lip along the inner edge gets ground down. heres old post on it. his grinding jobs was left pretty rough. I used a flapper wheel to smooth my case right out. you dont need to grind any of the gasket face off, just grind the bump down may angle up abit magneto will come off.
https://www.hdforums.com/forum/dyna-...mpensator.html
I just used a piece of flatbar I got from work
Attached Thumbnails Screaming eagle clutch-prime-4.jpg   Screaming eagle clutch-prime-3.jpg   Screaming eagle clutch-prime-9.jpg
Sedonastrider
2014-2024 Touring Models
Jan 27, 2021 11:51 PM
RonaldL
Jan 12, 2019 11:17 AM
ColdRain
May 8, 2017 05:48 AM
pkrocker
Aug 18, 2015 10:05 PM
pjpockets
Sep 27, 2014 08:42 PM
