Fuel Problem 06 EGC
Old Jun 1, 2011 | 04:43 PM
burdes's Avatar
burdes
Default Fuel Problem 06 EGC
I have what appears to be a fuel problem with my 06 EGC. It has a PCIII, HD duel headers, Thrush slipons, Stage III kit. When I crest a hill, it will sometimes sputter, not backfire and not die. Most times it idles fine when stopped. It accelerates just fine and when I'm riding on flat streets at at 20 or 30 rpms it often "coughs," but if I crank the throttle, it accelerates without a problem. Whether is is cold or hot doesn't matter. I've changed plugs and plug wires, new air filter and ran a couple of tanks of injector cleaner. It is more prevalent when I get below 1/4 tank of gas. HD has done all the service up to 40K miles. I'm not sure if they changed the fuel filter at 25K like the manual recommends.
Is there anything else I should check before I dig into the fuel filter change. I'm not wanting to go though all that nonsense.
Thanks, Stacy
Old Jun 1, 2011 | 04:52 PM
petemac's Avatar
petemac
I would definitely find out if the fuel filter has been changed. I changed mine at 27k and it was really dirty. Also an easy thing to check and clean is the IAC hole behind the air cleaner. This can get clogged up with gunk and really affect the fuel/air mixture at idle.
supermanotorious
Mar 26, 2018 08:57 AM
Woodys03
Oct 14, 2015 08:09 PM
DJM23
Exhaust System Topics
Oct 27, 2010 08:39 PM
AlCherry
Sep 27, 2009 06:46 AM
Skulls
Oct 28, 2004 02:27 PM
