What is normal oil pressure?
Old Sep 19, 2019 | 01:44 AM
Keithhu's Avatar
Keithhu
Way to ressurect an 8 year old thread
Old Sep 19, 2019 | 06:56 AM
decencyxdefied's Avatar
decencyxdefied
**** mine is maxed out at operating temp, has been for the last 3 years. Oil change has not changed anything, runs fine, feels fine, so Im fine
Old Jan 31, 2020 | 07:18 AM
N00dles07's Avatar
N00dles07
Stage II
I have an 06 rg with the 103 screaming Eagle and idle when I 1st start It the pressure is up but after running it at little bit when u r at a stop sign is at 0 but 2nd you hit the throttle it is back off to normal is this a normal thing and has no oil pressure gauge so I don't now
Old Jan 31, 2020 | 12:59 PM
skratch's Avatar
skratch
if you have no oil pressure gauge, how do you know it is almost 0 at a stop?
Old Jan 31, 2020 | 04:31 PM
eighteight's Avatar
eighteight
That one puzzled me too...
perhaps the op meant to type
”No oil pressure on gauge”
Old Sep 19, 2021 | 11:10 AM
pholli12's Avatar
pholli12
6th Gear
Default Real old I know that to be true
Originally Posted by Oldjarhead
For all who care to know....... Synthetic oil is not thinner than dino oil, viscosity is viscoity. The molecular particles of synthetic oil are smaller allowing it to get into places dino oil doesn't like to go. This is why some bikes show more evidence of oil seepage after changing to synthetic. It also allows the synthetic to move more freely through your motor and since the particles are smaller, there are more of them in the same volume allowing it to cushion parts a little better. Some motors seem to like the dino better and some like the synthetic better. I personallyprefer amsoil 25W60. It seems to run a little quiter in my 05 TC. They clatter anyway. I'm gonna different lifters and see if that helps. BTW, my hot engine oil pressure, at idle, runs from 18 to 21psig. and around 45 to 53psig. at 3000rpm hot.
I know this real old but u say it’s not thinner but has molecules that’s smaller and creep . in smaller areas wouldn’t that make it thinner all in all it is thinner when hot is all u said but in molecule way lol
Old Sep 20, 2021 | 12:44 PM
qclassic's Avatar
qclassic
Originally Posted by SG Mike
If you look closely at the gauge I think you see that you are running around 5 psi at idle which is fine.
You should be fine.
Mike
mine sits at 5psi after riding at idle then up to 30/35 going down the road .I thought I had a problem when I got the bike
But read that it's nomal😌.
Old Sep 20, 2021 | 07:16 PM
miner999r's Avatar
miner999r
Mine machine when running and hot the oil press. is about 50/55 psi and about 20/25 at idle. I have a special spring in the cam plate which is otherwise stock. Before the spring a bout 30 / 35 hot running and about 10 +/- hot idle.
Old Sep 20, 2021 | 09:31 PM
qclassic's Avatar
qclassic
it's 32 psi not 35
Old Sep 20, 2021 | 09:53 PM
Weeboy1's Avatar
Weeboy1
Big vtwin is more about volume than pressure 10/32 is pretty normal. Beefing up the pressure relief spring isn’t necessarily doing you any favours . More pressure = less volume
