What is normal oil pressure?
Old Sep 23, 2021 | 11:45 AM
  #31
danny54's Avatar
danny54
Your bike is fine, I wouldnt worry about it
Old Sep 23, 2021 | 03:41 PM
  #32
roussfam's Avatar
roussfam
Originally Posted by Weeboy1
Big vtwin is more about volume than pressure 10/32 is pretty normal. Beefing up the pressure relief spring isn’t necessarily doing you any favours . More pressure = less volume
Exactly...
...A common assumption is that if the pressure is low, the pump must be bad. This is not the case. The pump doesn't pump pressure. The pump delivers a rate of flow. The single function of the pump is to take fluid from one place and put it somewhere else. Pressure is the result of resistance to flow...
Old Sep 23, 2021 | 09:42 PM
  #33
Max Headflow's Avatar
Max Headflow
Can you explain how more pressure = less volume? Not sure I understand.
Old Sep 23, 2021 | 09:45 PM
  #34
Max Headflow
As long as you are above 30 psi at 3000, life is good.
Old Sep 24, 2021 | 06:52 AM
  #35
roussfam's Avatar
roussfam
My bike when hot shows over 30 psi while riding but only about 5 psi at idle
Old Sep 26, 2021 | 06:07 PM
  #36
MikieT's Avatar
MikieT
07 streetglide and with that stock gauge if it's accurate, mine runs at 35-45 under load, idles at around 5/10
Old Sep 26, 2021 | 10:21 PM
  #37
pyuchem's Avatar
pyuchem
Mines at 27 to 29 psi while riding. Is that normal ?
Old Sep 27, 2021 | 06:02 AM
  #38
jake24lt's Avatar
jake24lt
Originally Posted by miner999r
Mine machine when running and hot the oil press. is about 50/55 psi and about 20/25 at idle. I have a special spring in the cam plate which is otherwise stock. Before the spring a bout 30 / 35 hot running and about 10 +/- hot idle.
The pressure relief spring only raises the high pressure cutoff, if the pump is up to the task, it does 0 for idle. A spring cant make pressure, it's there to stop over pressure. These motors are open bearing, ball, needle and roller. Unlike in the automotive world.
Ashnic
Milwaukee Eight (M8)
Sep 23, 2021 12:01 PM
djcos1
Sep 14, 2014 03:47 PM
drumster
Oct 1, 2012 12:01 PM
Talldog
Mar 16, 2012 08:15 PM
mantodou
Oil Archive (no new posts)
Mar 12, 2008 07:05 AM
