strange noise in neutral
Old Jun 16, 2011 | 08:46 PM
Jace's Avatar
Jace
I was told that the noise is neutral gear rattle and that its normal......
Old Jun 16, 2011 | 09:18 PM
speakerfritz's Avatar
speakerfritz
I wonder if that translates to a corporate risk analysis was done and a determination was made that it's not likely to fail during the warranty period.
Old Jun 16, 2011 | 09:48 PM
Ole T Sport's Avatar
Ole T Sport
My re-occuring nightmare...
Old Jun 16, 2011 | 09:52 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
When the IPB goes bad it will sound like a steel roller skate wheel being scratched on concrete and go quiet when you drop it in first gear. But neutral gear rattle is not normal or acceptable.
Old Jun 16, 2011 | 10:02 PM
Port Dawg's Avatar
Port Dawg
Mine does this as well...in fact I think all 2011's seem to have this noise....maybe FDHOG will chime in as he brought his bike to dealer and had them thoroughly check it out for the noise you are describing......verdict? Told it was normal
What can you do if you keep getting told it is normal?
Old Jun 16, 2011 | 10:29 PM
g money's Avatar
g money
Account Retired
https://www.hdforums.com/forum/touri...nny-noise.html
Click on the above link and read the older posts on this.
I've had that noise since 09.
Gary D.
Old Jun 17, 2011 | 08:19 AM
Toe Knee's Avatar
Toe Knee
My 2010 flht does the same thing. More so when real hot.
Old Jun 17, 2011 | 09:23 AM
Jackie Paper's Avatar
Jackie Paper
Originally Posted by Keith50
my bike did the same thing and the main drive gear was going bad and it eat the inner race .... Here is a picture of my inner race.
Is this the inner race out of bearing 6 in my attachment that is actually in the transmission side? (Inner primary race is 16.) I have never quite understood the relationship between it which supports the last gear and shaft coming through the transmission and the inner primary bearing which supports the same shaft on the primary side. What that making enough noise that you could not ignore? Last question is because mine at 40K makes a lot of primary noise and a couple of old school Harley guys say probably OK, just chain slap.
Old Jun 17, 2011 | 10:00 AM
Toe Knee's Avatar
Toe Knee
Sorry....flhtcu.
Old Jun 17, 2011 | 10:21 AM
56tbird's Avatar
56tbird
The only time I can hear it on mine is when I put the bike in neutral in the garage, the acoustics bounce around in there and I can just pick it up. Outside, I don't notice it.
