strange noise in neutral
Old Jun 17, 2011 | 10:25 AM
Port Dawg's Avatar
Port Dawg
Originally Posted by 56tbird
The only time I can hear it on mine is when I put the bike in neutral in the garage, the acoustics bounce around in there and I can just pick it up. Outside, I don't notice it.
Yep same here, I probably would not have noticed until I read FDHOG's posting about it awhile ago
Old Jun 17, 2011 | 11:35 AM
Ole T Sport's Avatar
Ole T Sport
Don't you guys remember the open primary belt drives, hard to hear over the exhaust but there sure was some rattling going on when that dry clutch was engaged.
Old Jun 17, 2011 | 06:47 PM
Potato_Potato's Avatar
Potato_Potato
Originally Posted by smithbrl
Mine had the same symptoms and the dealer replaced the inner primary bearing.
Me too - exactly the same symptoms @ 13,779 miles while on a trip — here is a paste from my WO:
Work Description: R & R MAINSHAFT BEARING
34091-08 RACE, INNER BEARING $14.00
9231 BEARING, ROLLER $11.55
There was, of course, gaskets, fluid, etc.
And in my case they replaced the tensioner - I would'a questioned the need and asked to see the tensioner but I wasn't paying, it was under warranty.
39929-06A CHAIN TENSIONER, PRIMARY $93.15
As I recall there has been quite a few with the same problem, likely due to inferior bearings, but wow the OP's at 500 miles is ridiculous. I just realized that I am approaching the same milage that my first one failed at.
Old Jun 17, 2011 | 07:22 PM
GPHDXLC's Avatar
GPHDXLC
Same with me, on 11 RK at 2300 miles.
Old Jun 17, 2011 | 08:44 PM
lh4x4's Avatar
lh4x4
I am glad that I am hard of hearing. I just ride them until they seize. Works for me.
Old Jun 17, 2011 | 09:40 PM
FDHOG's Avatar
FDHOG
Originally Posted by Port Dawg
Mine does this as well...in fact I think all 2011's seem to have this noise....maybe FDHOG will chime in as he brought his bike to dealer and had them thoroughly check it out for the noise you are describing......verdict? Told it was normal
What can you do if you keep getting told it is normal?
Hey Dawg! Here I am.
500 miles? I noticed mine sooner than that.
Dealer checked it out. Found nothing wrong "It's Normal"
Not being satisfied, I called the MOCO and talked to the tech dept. The "Official" word is Neutral Rollover, noise created by the gears slapping into each other while they are disengaged, causing no damage to the transmission. The MOCO logged my complaint, and gave me a case# just in case anything happens down the road. If more people start calling, maybe they'll do something about it. I switched to Amsoil Severe Gear, and the noise subsided a little.
I mostly learned to ignore it now.
Old Jun 17, 2011 | 10:29 PM
Port Dawg's Avatar
Port Dawg
Gears slapping into each other does not sound like a good thing........well glad I have 5 years of insurance in case this does become an issue down the line
KSRoadKing's Avatar
KSRoadKing
I think I heard this on my 11 RKC the other day. It was very hot out and I was just cruising around town. Got to a red light, heard the noise and just assumed it was the EITMS kicking in since I'd never had it kick in before. Now I'm a little concerned.
Old Jun 18, 2011 | 06:36 AM
FDHOG's Avatar
FDHOG
Sounds like marbles in the transmission! Pull in the clutch and it goes away.
Dawg, I have the 5yr plan too. I developed the ride it till it breaks attitude. It's their problem for the next 4.5 years.
Old Jun 18, 2011 | 10:21 PM
Port Dawg's Avatar
Port Dawg
Right there with ya in that line of thinking!
