FLHTC 2003 ignition
Old Jun 12, 2011 | 10:51 AM
dave0377's Avatar
dave0377
Stage IV
Default FLHTC 2003 ignition
If anyone has insight or tips on 03 flhtc ignition please help. I just finished installing 95" SE cylinders and heads. I also replaced the stock module and coil with an SE (J01964). Bike fired right up ! Couple of very short rides in town then took it out for a longer ride. After about 5 miles it just shut off. waited 10 minutes or so then fired up. Ran a couple miles, same thing. Stuck the stock module and coil back on. No change. This happend 4 times before I got it home, sooner each time and longer wait. Wires all seem fine, lights stay on, gets fuel, runs excelent till it shuts off. Is there anything except thie crank position sensor to check ? Thanks Dave
Old Jun 12, 2011 | 10:55 AM
dawg's Avatar
dawg
Start by pulling the codes and see what you get for codes.
Old Jun 12, 2011 | 08:55 PM
dave0377's Avatar
dave0377
Stage IV
Will do, got a code list for injected and will check with that mine is a carb, seems like aplicable codes should still match. Thanks Dave
Old Jun 14, 2011 | 09:38 PM
dave0377's Avatar
dave0377
Stage IV
Thanks for all the response The pull code sequence for the injected didn't work or perhaps it just didn't know there was a problem. I replaced the crank position sensor and 40 amp. breaker. Seems fine now, the tech at the shop felt sure it was connections at breaker, the wire connections were fine, so I didn't change them. Bike seems fine now. The tech did say the older CPS with the metal stud in the center had been known to lose the stud and wind up wires in the lower end, the new one has a rubber cap covering the end. They didn't have a breaker so I pirchased a 40 amp at the NAPA store for $8 that fit the stock mount. Thanks Dave
Go Shovelhead Go
Shovelhead
Jul 15, 2015 08:46 AM
kevinrdc
Jan 17, 2014 02:34 AM
Chap
Apr 22, 2012 09:26 AM
Vretsam
Jul 12, 2011 05:52 PM
jurob
EVO
Oct 3, 2009 10:06 AM
