Drive belt alignment
Old Jun 14, 2011 | 06:48 AM
GPS's Avatar
GPS
Stage II
Default Drive belt alignment
Hello everyone, I have just put new tires and brakes on my 01 Ultra Classic and my question is on belt alignment. Should the belt ride in the middle of the rear sprocket? When I roll the wheel forward the belt always shifts over to the left side of the sprocket, when I roll the wheel backwards it will shift to the inside or right side of the sprocket. I would get binding on the belt when rolling tire backwards, I have since adjusted so the wheel spins freely frontwards and backwards, but the belt still shifts side to side. Just want to make sure this is normal.
Thanks
Old Jun 14, 2011 | 07:05 AM
paguy's Avatar
paguy
As long as the belt isn't rubbing, it shouldn't matter which side it rides. BUT, what determines where it rides is the wheel alignment. There are posts on this site that explain how to check alignment. I believe the manual has info on this and you tube.
Old Jun 14, 2011 | 07:31 AM
bohica48's Avatar
bohica48
Thanks
I'm pretty sure that the side to side is normal, going forward moves left, backing up moves right.
Old Jun 14, 2011 | 07:52 AM
dog155's Avatar
dog155
There is an alignment tool the check very easy to make.Checks the between axle centers and swingarm pivot bolts.As long as belt is not making shavings it should be Okay.
Old Jun 14, 2011 | 08:23 AM
Ronp42's Avatar
Ronp42
Account Retired
What Dog155 said, I saw a video on Youtube where the guy made a tool out of a welding rod. Had a 90 degree bend on one end and a small o-ring on the other. He poped the dust covers off the swingarm shaft, hooked the tool in the hole and slid the o-ring to the center of his rear axle shaft, then went and compared to the other side. I just measure with a ruler. Look at the sides of your belt, you can tell if it's been rubbing too hard!!!
Old Jun 14, 2011 | 10:28 AM
gmc's Avatar
gmc
There is no alignment for the belt, the front pulley is wide enough to allow the belt to run in alignment with the rear pulley. Make sure your rear wheel is adjusted correctly and your ok. I think most will notice the same effect you do when backing up. You shouldn't have much of a gap on your rear pulley, has the belt been replaced and are you sure you have the right belt on there?
Old Jun 14, 2011 | 07:24 PM
GPS's Avatar
GPS
Stage II
Thanks for the replies, I found the youtube video with the rod and o-ring, will go out to shop and rig one up. I have never replaced the belt and am sure it is still the original, very low miles on 01 bike, anyway the belt definatly does not fill the whole rear sprocket surface.
Thanks again everyone.
Mihail Petev
Oct 21, 2018 05:28 PM
Spec36
Apr 2, 2018 07:11 PM
kbrain
Feb 27, 2011 01:07 PM
TexFordD
Nov 24, 2009 05:24 AM
starbound
Oct 2, 2006 07:46 PM
