adjust steering head bearings??
Old Jun 27, 2011 | 04:46 PM
  #41
Guitar4Him's Avatar
Guitar4Him
Originally Posted by relli
hardest part def radio scews. got three in not sure bout the fourth but........ thanks to all for thier help.
Anybody that says those radio screws aren't a royal pain is a magician...
Old Nov 14, 2012 | 08:44 PM
  #42
zgarsnwine's Avatar
zgarsnwine
Stage I
to adjust the neck bearing on n FLHT 03, with the bike off the ground (same distance front and back tires), do I adjust the star nut from the FRONT of the bike (fairing / radio removed) or from the side with the handle bars (steering) turned (left or right ) all the way to get access ?
Old Aug 22, 2013 | 07:40 PM
  #43
04ctd's Avatar
04ctd
good thread....the video makes it worth a bump...gonna do this tonite....my 2010 with 7k miles has a loud clunk
Old Mar 23, 2020 | 02:02 PM
  #44
miketv84's Avatar
miketv84
I have an 07 RK flhr with a batwing installed. The adjustment is made with that fairing removed? The svc manual is kind of vague. Obviously the only way to get to the starnut is with it removed . I have the swing correctly adjusted with the fairing off but when it's back on the swing is tighter. Just want to make sure I did this correctly.
Old Mar 23, 2020 | 02:09 PM
  #45
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
The swing test is done with everything in riding, OEM condition. You use a 6" long 1/4" drive socket extension up the bottom of the neck and turn SLIGHTLY to adjust (righty tighty)
Old Mar 23, 2020 | 02:15 PM
  #46
miketv84's Avatar
miketv84
yup I adjusted it according to the manual. However once I put the fairing back on it's not within spec. So is the correct configuration without the fairing?
Old Mar 23, 2020 | 02:24 PM
  #47
miketv84's Avatar
miketv84
if I have the bike jacked up with everything installed after the adjustment I am able to move the bars side to side with one finger.
Old Mar 23, 2020 | 02:37 PM
  #48
BrandonSmith
The bike has to be fully assembled in original OEM condition (no phone or gps mount on the fairing or bars, etc.), clutch cable disconnected, jacked up off the ground, and perfectly level front to rear and side to side. The test is not done by feel nor from lock to lock. Of course when you're out riding that will tell you by feel if it is too tight or too loose, but on that year frame, I wouldn't take a gamble to adjust it by riding feel. I think that year has some major wobble issues if I'm not mistaken.
Old Mar 23, 2020 | 02:38 PM
  #49
BrandonSmith
Old Mar 23, 2020 | 03:29 PM
  #50
miketv84's Avatar
miketv84
Thanks . So I'm really just trying to confirm that checking is done without this batwing fairing. Based on the manual it appears that way.
