adjust steering head bearings??
Old Jun 17, 2011 | 04:45 PM
Notgrownup's Avatar
Notgrownup
Guess i'm fittin to find out.
Old Jun 17, 2011 | 04:55 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Originally Posted by Guitar4Him
I wasn't talking about sliding it in....I was referring to getting those pesky screws back in...especially the two closest to the handlebars.
Your 100% right there.....I found a cut off allen wrench works the best but it slow going...
Old Jun 17, 2011 | 07:16 PM
Jackie Paper's Avatar
Jackie Paper
Since I do not have one just guessing here but did you see the video of the guy using the ball nose allen wrench to remove the radio in notgrownup's post above. He like just stuck the wrench up there and the next frame out came the radio.
Old Jun 17, 2011 | 09:46 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Time lapse photography....Even with those ball end socket wrenches, those two bolts in the front are a bi##h to get out and in....
Old Jun 18, 2011 | 08:13 AM
relli's Avatar
relli
so i watched the video. not too hard im thinking. if the video gave what year the bike was i didnt catch it?? am i understanding that there is a lock washer- a lock nut and the strg head nut itself??
Old Jun 18, 2011 | 08:25 AM
Notgrownup's Avatar
Notgrownup
fROM THE LOOK OF THE BIKE I WOULD SAY A 2003
Old Jun 18, 2011 | 01:36 PM
dawg's Avatar
dawg
You can fashion your own tool out of a long flatblade or a piece of welding rod. Snap on makes a tool that is not too awful expensive and works great for this, Snap-on NBAT1
I think it's under $40
Old Jun 18, 2011 | 02:35 PM
Guitar4Him's Avatar
Guitar4Him
Trust me...getting the screws OUT is the easy part. Wait until you start trying to get them back in....then, you'll see what we've been talking about.
Old Jun 18, 2011 | 03:42 PM
jjnoble's Avatar
jjnoble
If your handlebars are not straight (one side closer to you the other pushed out), I guess that means the forks are not straight, could you straighten them by loosing this bolt? Kind of like loosing the neck on an old string ray bike and turning the bars to where you want them.
Old Jun 18, 2011 | 08:01 PM
1Harleyrdr's Avatar
1Harleyrdr
from your post im assuming you removed the outer fairing and radio ? able to use a wrench or socket at that point??
I did remove outter fairing and radio. Not a big deal, I have the 1 1/2 socket for the nut. I used a snap on ball allen wrench and a small wrench for leverage and the radio mount bolts came out no problem. A little piece of duct tape on the allen keeps the bolt from going strange un recoverable places. Good info about me not having the locking nut i was Pissed. Over it now thanks to this forum. I used a long nosed punch pin to adjust the tension on the neck bearing. Went on a 400+ mile test ride yesterday evening to check it out. all works well. MUCH Less WOBBLY motorcycle at speed.
