Finding neutral
Old Jun 18, 2011 | 09:09 PM
Wassup8687's Avatar
Wassup8687
It'll get easier with time. Try Redline in the primary and tranny. It'll make out much easier to get into neutral.
Old Jun 18, 2011 | 09:24 PM
Rich67's Avatar
Rich67
600 miles on My Limited switched to Redline primary oil and Redline gearoil in the tranny seemed to help mine.
Old Jun 18, 2011 | 09:31 PM
TORQUEY's Avatar
TORQUEY
Originally Posted by david christopher
when its time for a oil change, put some synthetic in the trans ( it wil make finding netural easier ) and for the heat, take the lower fairings off for the summer
Absolutely! However, I found that the Syn3 at my first oil change was like the stock dino oil as far as finding neutral was concerned.
When I switched to Amzoil synthetic, shifting became much more positive and neutral is now MUCH easier to find.
Old Jun 18, 2011 | 09:33 PM
Troubleman's Avatar
Troubleman
That's what I use my heel shifter for. A little tap with my heel seems to find it much easier than using my toe. Just me.
Old Jun 18, 2011 | 09:37 PM
mmcbeat's Avatar
mmcbeat
Some folks say it gets better after you put some miles on your bike, others suggest changing the oil in the tranny. I think it's just a matter of getting used to your new scooter.
May not be related but I would rather have a little trouble finding neutral than trying to shift into second and hitting neutral instead.
Old Jun 18, 2011 | 09:48 PM
TheSinistral's Avatar
TheSinistral
I had same problem with my new Road Glide. Three things:
1) It got progressively better with miles.
2) I read here that it is easier to find N while still rolling to a stop (works!)
3) It got a TON better when I got the 1000 mile service with synthetic. If I had to guess, I would say they adjusted something??
Almost a non-issue now.
-Sin
Last edited by TheSinistral; Jun 18, 2011 at 09:49 PM. Reason: Edited for clarity...
J2X's Avatar
J2X
I found letting the clutch out a little and allowing the bike to move slightly then pull in the clutch and then push up on the shifter, it seems find neutral naturally. Almost as though you loosened up the transmission a bit.
Nice bike.
Old Jun 18, 2011 | 09:51 PM
klaybus's Avatar
klaybus
Syn seems to work with both my Harleys. Nuetral has never been a problem.
Let's see that new bike!
Old Jun 18, 2011 | 10:26 PM
Ole T Sport's Avatar
Ole T Sport
Get used to it
Old Jun 18, 2011 | 10:34 PM
banddirector's Avatar
banddirector
Originally Posted by crackercap
it will get a little easier with mileage.
