Warpped rotor
Old Jun 20, 2011 | 07:18 PM
bigtwin1228's Avatar
bigtwin1228
Default Warpped rotor
If the rotors our off of the wheel how can you tell if their warpped? I assume laying them flat down on the bench and as you work around the rotor with your finger there should be no wobble. Sorry if this is a dumb question but mine do wobble very little when doing this. And I can't find how to check this in the manual.
Old Jun 20, 2011 | 07:30 PM
Dionicio's Avatar
Dionicio
Never had tried Your method, but it sounds like a good way to me!
Old Jun 20, 2011 | 07:36 PM
soos's Avatar
soos
Use a straight edge. How do you know if your bench is flat?
Old Jun 20, 2011 | 08:13 PM
dnitram's Avatar
dnitram
Raise up the front while the rotor is on the bike and use a dial indicator against the outside edge of the rotor (must anchor the dial indicator so there is no way to just hold it to get a good actual reading). I suspect you're referring to some sort of front brake pulsation...
Old Jun 20, 2011 | 08:17 PM
roadgliderick's Avatar
roadgliderick
if u have ABS thats what u might be feeling. but a warped rotor is not unheard of my 09 SG had a warped rotor and replaced under warranty.
Stomper-63
Jul 6, 2020 03:11 PM
Stomper-63
Wheels/Tires
Nov 26, 2010 03:28 AM
soos
Oct 24, 2010 09:33 PM
Figstr
Jan 5, 2010 11:08 AM
Harleyfan
Oct 9, 2005 08:14 PM
