2002 Ultra Classic just dies
Old Jun 29, 2011 | 08:02 PM
DDDeibler's Avatar
DDDeibler
2nd Gear
Unhappy 2002 Ultra Classic just dies
My 2002 Ultra just dies out and I mean everything lights, radio, engine, everything. It only does it for a second, but I have to turn the key switch off and back on to start it and get it to run properly. There is no pattern some time it is hot or cold out and I have riden over 100 mile and other time it happen at just 3 miles and one time so far while I was waiting for a stop light. The motorcycle shop can not get it to recreate the problem even though they had it for a month and rode it over 150 miles. I got it back and it happened at the very next day after 58 miles, but died at 24 miles on the ride home from work on a 80 degree day, and again at 27 miles since the last time but only 3 miles into the ride the very next day. The last time I had put over 300 miles since the last time and it had been three weeks before it happened and it was 95 degrees out. Any ideas?
Old Jun 29, 2011 | 08:06 PM
dawg's Avatar
dawg
Replace the ignition switch. Sometimes over time the contacts get messed up from the heat, etc. I can't imagine with those symptoms that the shop didn't automatically do that.
Old Jun 29, 2011 | 08:08 PM
T3BEAR's Avatar
T3BEAR
Does your bike have the 40/50 amp breaker next to the battery?
Old Jun 29, 2011 | 08:10 PM
dawg's Avatar
dawg
Oooh yeah, that's the other issue. Forgot about that one.
Old Jun 29, 2011 | 08:12 PM
DDDeibler's Avatar
DDDeibler
2nd Gear
Both the ignition switch and the breaker where replace while at the shop.
Old Jun 29, 2011 | 08:38 PM
T3BEAR's Avatar
T3BEAR
If it is losing all electrical power it has to be in that circuit I would think.
If not there is a bad ground somewhere.
Old Jun 29, 2011 | 08:44 PM
rk62's Avatar
rk62
Seeing that you are losing everything, it could be the connection at the battery gauge since I believe it is in series with everything. The connection could have been compromised during a fairing removal.
Old Jun 29, 2011 | 09:07 PM
Hx3's Avatar
Hx3
I would replace the main circuit breaker with an inline fuse and ditch the ring terminals that connect to the circuit breaker. Both are problematic and contribute to the problem you are having.
Old Jun 29, 2011 | 10:01 PM
Harleyboyddk's Avatar
Harleyboyddk
Absolutely! Great call. Fixed the same problems I had last year, Out in 108 temps and no issues since.
Old Jun 29, 2011 | 10:09 PM
Paniolo's Avatar
Paniolo
With the bike running, hold the thick harness of wires next to the steering neck that run from the tank to the fairing. Shake the harness up and down, back and forth and see if the bike cuts out. In those older bikes sometimes the copper strand wiring breaks INSIDE the insulation. You can't see it, it often passses enough current to function, but vibration and movement will cause an interruption.
