I took a trip in August from Savannah to Baltimore, primarily on I-95, averaging around 80mph ('06 RK Classic, completely stock intake and exhaust, loaded down with a large rucksack on the backseat and a smaller one on the rack).
At 150 miles my gas light would go on and I'd fill it up at about 160 miles with 4.5 or 4.6 gallons. I averaged about 34 mpg.
Going down to Biketoberfest along Hwy 17 and A1A from Savannah averaging 55mph, (still stock[&o], two up, small ruck on luggage rack) I filled it up at about 180 miles and the light hadn't come on yet. I think I figured it out to be around 48 mpg.
So that's a difference between about 34mpg and 48mpg. Very significant and I'm sure speed was the factor.
I don't know about crappy winter gas, but I do know that when gas is cold you'll actually get more in your tank. They say the best time to fill it up is in the morning during the summer because gasoline tends to expand considerably when it warms up.
I would think if it was the SERT I'd see crappy mileage at all speeds. Based on the other
responses, I think you just pay a big penalty in fuel consumption with speeds over 65.
I could be wrong.
A couple things were touched on here. Aerodynamic drag being the major. A batwing slips through the air cleaner than a "barndoor", a frame-mount better than a batwing, lowers better than not, hardbags vs, soft, etc. Minimizing turbulence at the back also plays a role, once you slice through the air, it has to return. The swirl motion of the air returning to it's original path can be "spoiled" to your advantage. Case in point: club racing VW's years ago, rabbit GTI's were always slightly faster than Sciroccos due to a larger rear surface area for the wind swirl to "push" the car forward. Efficiency whether measured in speed or MPG's is part of basic physics 101. Winter fuel is another subject. Because of lower temperatures, refineries blend more volatile fuels in with the gasoline. Ether is a common winter additive, propane in extreme climates. Imagine the evaporation in summer with ether, that's why modern gas caps are tightly sealed.
I been getting an average of 43mpg on my 06 RC ,70mph two up and SE Pro/SE a/c and the HD download. I wounder if the sert is hurting fuel milage?
The SERT is not installed in the bike, it's only the interface between the computer and the bikes computer (ECM) used to program it and then is removed. The PCIII is installed in the bike and is just one more piece of electronics to go bad at the wrong time.
2014 Twin cooled FLHTK, SE Street Cannon exhaust, stock cat, Fuel Moto intake, DK Customs external breather kit, PowerVision 2 running a tuned map from Fuel moto. Last fillup was at 270 miles with 5.2 gal for 51.9 mpg using Non-Ethanol Premium! Thats being conservative with the throttle on Oregon backroads averaging 60-65. With the crap ethanol fuel, that figure is closer to 46-47mpg and has been as low as 44. Your fuel will make a big difference in your mileage, reguardless of what the politicians would have you believe
