Are you saying that you just don't have the fob with you or that your system is without a fob?
Don't know that this will work without the fob being close by:
1) Set your kill switch to off
2) Quickly turn the ignition switch on, off, on, off, on
3) Immediately press and let go of the left turn signal switch twice (press, let go, press, let go)
4) Press and let go the right signal once
5) Current PIN will be displayed on odometer
FWIW, the default on my '10 King was 31313
nope, you have to have the fob with you to do this. otherwise, what would be the point?
U guys r too funny! the cops did show up....twice! my laptop batt died so i couldnt converse with u guys anymore! I DID trick the computer into thinking the bike had no security system.....took me 10 freaking hours to figure it out though, without a wiring diagragm......a theif couldnt....hell most techs couldnt.....I just am lucky like that.....and 30+ years of wrenchin helps.....11 years teachin
