Steering Head Bearings question
Old Jul 8, 2011 | 08:01 AM
rg_dave's Avatar
rg_dave
I used redline grease. I've don it a ouple of times now. I haven't had any of the dripping issues many have talked about and my bike lives in 100+ weather much of the year.
Old Jul 9, 2011 | 06:00 AM
jamesroadking's Avatar
jamesroadking
Their's no need to disassemble the triple tree to grease the bearings at the 1000 or the 10,000 mile services. Just shoot high temp grease into the zerk fitting until it starts to come out. When you got the bike up in the air, (usually when I'm changing tires), before removing the tire I just shake the front tire and feel if it feels too loose. When you get about 50,000 miles, or if you have any handling problems, or a wobble in the turns feeling, you could take the front end apart and inspect the head bearings and races, hand pack the grease, tighten head nut adjustment.
Old Jul 9, 2011 | 07:49 AM
lonerider2's Avatar
lonerider2
I didn't change the grease zerk but I did have a grease gun with a rubber hose instead of the solid metal standard on most grease guns.
Old Aug 18, 2011 | 10:05 PM
Port Dawg's Avatar
Port Dawg
Originally Posted by skydude426
I had to remove the chrome piece below the head light to get a greese hose on the fitting. It took most of a tube of HD special purpose greese. I'm glad I did it as it obviosly didn't get done at the 1,000 mile service. Next time I'll change the zerk to a 45 degree one but I didn't want to run after the part when I did it.
Same here.......they neglected to do it at my 1K service as well......
can you add grease while on the jiffy stand? I can see where the zerk is........this is new to me, where can I get everything I need to do this service?
Old Aug 18, 2011 | 10:35 PM
RAP's Avatar
RAP
Use high-temp grease!
Old Aug 19, 2011 | 07:43 AM
mrfikser's Avatar
mrfikser
lucas makes some stuff called 'red and tacky'...its not suppose to drip so much..you might try that..instead of regular grease which drips..sometimes for months
Old Aug 19, 2011 | 09:38 AM
gtrplyr's Avatar
gtrplyr
Doesn't the steering head bearings need to be adjusted as well @ the 10k service? I am doing my 10k myself, but have never done a steer head so I called the dealer to have that done and they want 1.5 hrs to adjust and grease. Can grease be picked up at local dealer?
Old Aug 19, 2011 | 11:16 AM
Terrabella's Avatar
Terrabella
Red & Tacky
Old Aug 19, 2011 | 11:23 AM
Port Dawg's Avatar
Port Dawg
Heard this Red and Tacky mentioned a bit...looks like stuff a lot are using
Old Aug 19, 2011 | 11:35 AM
CarrollB's Avatar
CarrollB
I just did my 10K service before leaving on a 1700 mile trip. Checked the play in the head bearings per the manual while on the jack stand. No adjustment was needed. Changed all three fluids, cleaned and lubed the air filter, checked the tread wear and air pressure in the tires, and rode it. After 1700 miles in the mountains I need to check the level of my brake fuild. When you look at the service required for the 10K and then what a dealer charges you it is easy to justify doing it yourself. If I think the drive belt is to loose I'll take it to the local indy for adjustment. They didn't grease the head bearings when I had the 1K service done for $300. I filled the head with grease myself using a high temp synthetic wheel bearing grease. Doing any of the required maintenance yourself will allow you to spend the $300+ for a good jack to make the work easier.
TheBanditColorado
EVO
15
Sep 11, 2013 07:54 AM
Steel Wheels
Jan 30, 2012 07:00 PM
Talldog
Sep 24, 2011 02:28 PM
gilmour68
Aug 12, 2010 04:58 AM
tallboy56
Aug 17, 2009 11:31 PM
