New Gremlin
Old Jul 8, 2011 | 06:09 PM
watercop's Avatar
watercop
Default New Gremlin
My 06 RKC runs very well with a stage one upgrade, vance and hines, and about 15K on the odometer. Recently I've developed a gremlin problem where out of no where the bike simply shuts off..as if I hit the kill switch. There doesnt seem to be any rhyme or reaseon to when it happens. It is not frequent.....and no I am not accedently hitting the kill switch. There are no codes stored. I'm a pretty decent wrench, but dont know where to start. It is a clean shut down so I am assuming it is electical, especially since the bike generally runs great. Would appreciate a few starting points if anyone has had a similar problem. I'm pretty puzzled...
Old Jul 8, 2011 | 06:46 PM
jmacdonald5's Avatar
jmacdonald5
have you messed with the ignition switch at all?...a loose wire there could cause it..
Old Jul 8, 2011 | 08:07 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
ignition switch or run stop switch,that wear i would start.
Old Jul 8, 2011 | 08:39 PM
NoKenDo's Avatar
NoKenDo
If it happens while you're going down the road, next time reach down
with your left hand and give the fuel line a twist where it connects to the tank.
I had the same symptoms on my '06. I had to replace the connection.
Hope this helps.
Old Jul 8, 2011 | 09:53 PM
Black_Hog's Avatar
Black_Hog
I had a similar problem with my 1986. I never turned my stop/kill switch off.
After a very long diagnostics voyage, the stop/kill switch was bad. It drove me and a great Harley mechanic nuts.
Changed the complete switch with wires. Ran much better after that.
Old Jul 9, 2011 | 08:43 AM
AlanStansbery's Avatar
AlanStansbery
This is probably not much use, but just in case... I remember reading about an issue with the main breaker (40A?) on certain year bikes. It got hot, and malfunctioned. Then was ok again when it cooled off. If you're stuck as to cause, it might be worth a try to replace it with a known-good, and see if your gremlin disappears...
Alan
Old Jul 9, 2011 | 10:20 AM
larsfum's Avatar
larsfum
The circuit breaker issue is supposed to be on 2001- 2003 bikes
http://www.pvc.maricopa.edu/~preston/M1151.pdf
That being said, it sure sounds like a breaker problem. Check all of your connections to the breaker. You can also try jumping the breaker while it is happening to see if it solves the issue. I would not advise riding the bike while bypassing the breaker though.
Old Jul 10, 2011 | 11:43 AM
watercop's Avatar
watercop
Which breaker are we talking about...Ignition?
TravisD27
May 2, 2018 01:44 PM
firefour
Nov 19, 2017 04:39 AM
rjames
Oct 10, 2010 10:25 AM
chop09
Feb 24, 2008 04:56 PM
