Rear end rattle on bumps
Old Jul 10, 2011 | 12:41 PM
JRBass's Avatar
JRBass
Could be one of those little rubber pieces on the exhaust mounting brackets is cracked or missing or slipped out of metal bracket on bottom of saddlebag guard. Happened to a buddy a couple of weeks ago.
Old Jul 11, 2011 | 05:54 AM
Rickr01's Avatar
Rickr01
Originally Posted by SDVmnt
I had the same sound on my 2010SG. I'll guarantee it's the back saddlebag mount and the inside of your rear fender. Mine was only on the right side. Took a piece of rubber weather stripping I had in the garage and sandwiched it in there. If I remember correctly there is already a piece of black foam in there from the factory.
Ding Ding Ding....Rear Fender facia. It turned out to be my rear facia attachment. As you mention, there are two pieces of thin rubber sandwiched between the rear facia, rear fender and that metal tapped bar that holds it all together. The rubber strip on the right side was mounted too low to do any good. I ripped it all apart last night and readjusted the facia and put in new rubber strips. All Good! Thanks everyone.
Old Jul 11, 2011 | 07:53 AM
2010 Glide Rider's Avatar
2010 Glide Rider
No rubber strips noted in service or parts manual. I had my rear fender off recently and there were none on mine. ?? Just sayin'.
Old Jul 11, 2011 | 08:16 AM
SDVmnt's Avatar
SDVmnt
Be it in the service manual or not, they were most definitely there.
Knew that's what it was too. Drove me absolutely batshit crazy.
Old Jul 11, 2011 | 04:26 PM
Rickr01's Avatar
Rickr01
Yep, My factory book doesn't show the rubber strips either, but they are there. Placement is critical. A little too low and rattle rattle rattle....Tough to find too!
Thanks alot SDVmnt! You saved me a lot of time. Rick
P.S. If anybody else does take theirs apart for the same issue, I made another tiny modification. Right where the facia overlaps the bottom side of the rear fender, the vibration tends to cause the fascia to rub against the fender and take the paint off where you cannot see it. Good spot for rust to start. I touched mine up and let it dry well, then put a small section of 3M clear paint protection film on the fender edge Its hidden behind that very small section of Fascia. I then put some commercial grade double sided taped between the two pices before tightening the bottom most screws back up. No more rubbing on the paint.
Old Jul 20, 2011 | 07:16 PM
METALKAT's Avatar
METALKAT
Same rattle here, no rubber pieces at all but I bought mine from another member. Manual didn't show any rubber parts which I thought was odd. Made my own rubber strips and the rattle went away.
Old Jul 20, 2011 | 07:24 PM
DaSchpiel's Avatar
DaSchpiel
Get it checked out... Mine began making some tinging sound on bumps the other day. Happened to be taking in for service. When the wrench got it on the bench he found my rear pulley had some weld cracked that caused my belt to nearly come off the pulley. End result is in shop, replaced wheel, pulley, bearing set, belt.... Bike was 2 weeks old and has 1200 miles on it. I'm not saying this is what has happened but dont overlook it either.
Good luck !!!
Old Jul 20, 2011 | 08:22 PM
tincup64's Avatar
tincup64
i'm happt to hear i'm not losing my mind. i hear the exact thing the OP described on my 2010 flhtk. its not typical loose things. gratefule that i now have something to investigate.
tin
Old Jul 20, 2011 | 08:40 PM
usmc3468's Avatar
usmc3468
Had the same problem, found my exhaust crossover mount bracket was broken in half.
electricking
Jan 9, 2022 10:52 AM
Glenn1911
Aug 27, 2020 07:47 PM
paulmj
2014-2024 Touring Models
24
May 5, 2017 09:29 AM
rhlhamlet
Jul 23, 2012 12:38 PM
pled55
Jun 30, 2012 01:42 PM
