Starter grind fixed
Old Jul 16, 2011 | 09:30 PM
streetglide44's Avatar
streetglide44
Ran today in 93 degree heat. Heat index closer to 100. Actually got stuck on interstate for 20 minutes in one spot. Turned ignition off several times in a 5 hr test run. From what I've seen, my starter grind is gone. Hope you all have good success too.
Old Jul 16, 2011 | 10:34 PM
user 8373900's Avatar
user 8373900
I had an 07 Ultra Classic and had the same problem. I am suspecting you have a compensator issue.Or the bad spot on the starter gear just hasn't stopped at the right place yet.
Old Jul 16, 2011 | 11:07 PM
speakerfritz's Avatar
speakerfritz
super...congrats
Old Jul 21, 2011 | 07:12 PM
speakerfritz
hows the grind repair holding uP?
I am curious about something....did you step torque the thru bolts....starting a say 20 inch lbs, then 30, then 40, then 50?
Old Jul 21, 2011 | 07:54 PM
Notgrownup's Avatar
Notgrownup
MOCO had a tech bulletin about starter grounding. Had a exhaust bracket added to help with grounding ...High torque starter helped.
Old Jul 21, 2011 | 09:14 PM
streetglide44
I've had no more issues. I did not torque the bolts(do not own torque wrench), I did get on it pretty tight though with blue loctite.
Litten Racing
Jan 14, 2025 07:32 PM
Mposton42
General Topics/Tech Tips
Nov 23, 2015 07:07 PM
Pitbull_Dallas
Sep 23, 2014 07:26 PM
kyfatboy1972
Apr 14, 2012 09:14 AM
